Tamiya TB-Evolution II >
Old 03-15-2002, 09:51 AM
  #106
Dragon: That's really bad.. wouldn't it be good if you could get your escs fixed in here? If you do need any help with your ESCs, do let me know and I'll might just fix it for you for a good price.
Ivan is offline
Old 03-15-2002, 05:49 PM
  #107
Alvin's Avatar
Ivan,
Do you have a set-up which can repair surface mounted components? Wow... my schulze esc which I got back recently, returned with the damaged surface mounted transistors.... I could not identify their part numbers (melted) but the pins are waay to small. I've modified the surface mounted resistors on graphic cards before, but those sm fets are just too small...
Alvin is offline
Old 03-15-2002, 05:57 PM
  #108
Alvin's Avatar
I guess these are the fets, the repair price listed 'em
Alvin is offline
Old 03-16-2002, 08:51 AM
  #109
Alvin, Yes.. I have a setup to repair surface mount parts. It's NO joke manual soldering them especially when they are super-small. If you need need any help, you know where to get it...
Ivan is offline
  #110
Dragon's Avatar
WWOOOooOOOooooo.....tiny....what are they for anyway
Dragon is offline
Old 03-16-2002, 08:54 AM
  #111
I'll need to take a look at the fets up close before I could tell you if it's really worth repairing. It doesn't help much if the markings are gone.
Ivan is offline
Old 03-16-2002, 08:57 AM
  #112
TB01 Aluminum Steering? Can this be used on a TB EVO?
Ivan is offline
Old 03-17-2002, 12:31 PM
  #113
Aluma's Avatar
hey guys, what other spur gear can be used? This .4 pitch pinion and fine spurs suck! I race on parking lot style track thats blown and sprayed, but still little pebbles make their way into the gears and mess them up. (and as you know they aint cheap!) plus you have to disassemble half your car to change to a new pinion.
HELP. robinson? HPI?INTEGY? tb01? tg10?
Aluma is offline
Old 03-18-2002, 04:22 AM
  #114
Alvin's Avatar
Aluma: rc-cross.com has a TB01 spur gear adaptor, it *may* work, do ask the other members for confirmation.
OTOH, whilst on my TB01 with the carbon chassis, i.e. visible spur gear we use the tamiya AV pinions and spurs. They have much less gear ratio and run very much noisier, but they seem to last very long. I did run the 0.4 for a while but they are a bitch to mesh andn strip too easily. Running costs were too high ;-) So went back to the AV stuff.
Alvin is offline
Old 03-18-2002, 09:46 AM
  #115
Dragon's Avatar
what is AV?
Dragon is offline
Old 03-18-2002, 01:00 PM
  #116
Aluma's Avatar
well, checked out rc-cross.com and found nothing of the sort. oh well,
AV designates a 48pitch METRIC which is what I'm looking for.
and so far the usual online hobbie stores dont carry that part.
cheapo TB01's spur gear bag...comes with a 55T,46T, and another.
I wanted to get that gear bag and try one of Kimborough, or robinsons plastic pro pinions.
Aluma is offline
Old 03-18-2002, 06:15 PM
  #117
Alvin's Avatar
Aluma:
Check this URL: http://www.rc-cross.com/page/TA-04%20TB-01.html
The spur adaptor is at the very bottom of the page.
I don't think AV is similar to the 48 pitch, we have tried running 48 pitch pinions with the AV spur gears, while no damage was suffered, it made alot of noise.... and we didn't dare run it for serious... events
TB01's spur set has 61T, 58T and 55T.
Alvin is offline
Old 03-18-2002, 07:11 PM
  #118
Aluma's Avatar
i read an article in Extreme R/C mag. about he evo2.
it says you can use Kim, RRP and some other gears on it. dont say which ones specifically though. it did have a pic with a pink pinion and a black spur(think it was the normal one)
so how do you order that adapter? everything's in japanese!! hehehe
Aluma is offline
Old 03-28-2002, 06:22 AM
  #119
Aluma's Avatar
you guys sound like you know what you're talking about....maybe you can help me out.... I'm pretty new to R/C and I got a tamiya car.(flame suit on) anyway, its got red springs which are soft and comes with this orangy oil.... its too soft a setting (figured that out cuz the car sparks sometimes) I adjusted preload and helped but not enough. I got the tuned spring set and i'm thinking blue front and yellow rear(firm, medium) but I have no idea as to what oil to use. my LHS only carries associated...would you guys know what weight matches the blue and the yellow springs given all shocks use 2hole disks inside?
I once put 30 wt with the stock chrome springs and the car looked like a pogo stick...I DONT want that to happen during the race!
Aluma is offline
Old 03-30-2002, 03:03 AM
  #120
Thumbs up
Onroad Electric and Nitro "State Championships" May 4th @ Small Cars Unlimited.
ZER01 is offline
