Tamiya TB-Evolution II
#647
hey guys i got another quick question for the evo 2's
Are the evo 2 suspension arms replacable with the evo 3 suspension arms? as one guy told me that the evo 2 have the same suspension arms as the EVO 3 and TA04 and some other XXX team losi car. can anyone confirm this please?
thanks
james
thanks
james
#648
To be honest, I am not entirely sure. I have just bought the Hardened TB Evo II arms and had no problems with them. You can get TB Evolution arms too, but aside from that, i am not sure what else are compatible. The Evo III probably are, since most of the two cars look the same except for the battery position and the drivetrain.
Sorry I can't help much more, i gotta admit, i'd like to know myself!!
#649
Brainteased...
You can do a complete conversion and use the TA04/evo3 arms on the evo2, but you have to use the upright, c-hubs and steering knuckles of the TA04/Evo3 as well... unfortunately, the stock evo2 suspension parts are slightly different and will be slightly off if you just replace the arms... a complete makeover is needed to make it work... hope this helps...
-Ian A.
-Ian A.
#650
if you use the ta04/evo3 arms you will be extending your wheelbase, even without those spacers. I have an evo2 and evo3 and i tried swapping out the arms but it made the wheelbase too long no matter what i did. then i looked at some pics of the evo2.5 and they used ta04ss arms. almost the same geometry and now your car will still fit your bodies. like eeyan said you will need to buy the uprights and c-hubs, etc to make it all work nicely, dont forget new hingepins like i did. i also fit an evo3 rear shock tower onto my evo2 so i can run the same bodies on my evo2 and 3. I would have done the front too but speedtechrc was out of front shock towers for the evo3. lemme know if you want to see a pic...
#652
Could someone please post how many teeth are on the EVOII's pinion and ring gears in the gear box's?
Thanks, Chris
Thanks, Chris
#653
heres a shot of the front with ta04ss arms
#654
rear
#655
evo 3 rear shock tower
#656
one more from the rear
#658
Originally posted by BrainTeased
thanks to
f.alonzo
andyroos
eeyan
ill be getting a evo 2 now for sure :P also what tends to brake on the evo 2 when you crash? my local track has wooden boards
thanks to
f.alonzo
andyroos
eeyan
#659
Thanks, Chris
Thanks, Chris
Ring Gear : 39
Bevel P-gear : 15
#660
JRRobiso
