Tamiya TB-Evolution II >
Old 09-19-2003, 02:09 PM
  #616
u make sure u got the bearing in to hold it.
the only other thing is if ur prop is distorted.
apart from that iam not sure.
sorry.
trf racer is offline
Old 09-19-2003, 06:56 PM
  #617
Default Bevel deformity
Thanks dude, those were some of the factors i was considering. I'm going down to the local R/C shop and getting me a whole new set of bevel gears and prop. And yes the bearing is in place.
Thanks for your help, i'll keep you posted on the result. Using this car, i have gone from C-main contender to B-main contender Ilove this car
Dragoonz09 is offline
Old 09-21-2003, 05:25 AM
  #618
rough512's Avatar
Default Re: bevel gear stripping
Originally posted by Dragoonz09
Greetings fellow evo 2tian's,
I have just received my tamiya evo2
and i must say i am very impressed with the car's looks and handling. unfortunately for my past two outings, it seems like my rear bevel gear is stripping. Has anyone of you ever experience this, if so please advice. I'm at my wits how to solve this problem.
Thank you very much in advance.
Daren
When I got my second hand Evolution 1, the bevel gear is also deformed. However, I think this is the previous fault. I think the propeller shaft was forcibly inserted into the gear box without prior checking whether the key on the shaft is properly aligned to that of the bevel gear. The result is that the rear wall of the bevel gear (the side that comes near the bearing in the gear case) have been deformed.
I also had a bevel pinion gear whose hole (where the prop shaft comes in) became rounded. This lost me my drive on the rear wheels and I only noticed this after losing a race. Hard part to replace.... I still have to find a replacement.
rough512 is offline
Old 09-22-2003, 05:19 AM
  #619
Thank you rough512,
I personally hand built the car from scratch(new), everything fitted well. yes i see your point on how the bevel can be deformed. But it happened twice dude, the second time even after careful rebuilt. I've now inserted a new bevel in, change the whole rear gear case and dropped in a brand new TGX ball diff in them. If this doesn't work i'm shelving the car and concentrating on my TAO4R Once again thank you for the tip, i'll try the car out and see how it goes. Incidently i've also reduce the braking travel on my transmitter, me thinks one more possibility could be my hard braking
Old 10-17-2003, 05:57 AM
  #620
Motorsports00's Avatar
ANYBOY tried using any Sqaure parts for Evo3 on the Evo 2??? do they fit??? ie - carbon shaft, deck bracers/ stiffeners etc???
Motorsports00 is offline
Old 12-02-2003, 10:12 PM
  #621
Default RUF
Hi, I've been browsing the entire thread.
You remarked that your mutant TB01 is faster that your EVO2?Could you post your TBO1 setups and modifications? I also noticed that apart from using a rear MR4TC shock tower, you are also using MR4 arms?
I have a TB Evolution 1 and I am satisfied with its handling. I'm just not happy seeing how the outdrives are wearing. I think the car could still be faster if the universal shafts are straighter.
I'm eyeing a TB01 / CF chassis being sold at our track. I'm planning to buy it but I'm not sure whether I can get it close to the handling my Evo1 currently has.
Thanks...
TRF512 is offline
Old 12-03-2003, 03:47 AM
  #622
shortyzz's Avatar
HI GUYS (LONG TIME NO SEE)
I JUST WANTED TO KNOW WHAT U THINK OF THE NEW TB-02 AND IF ANYONE NO WHEN OR IF THE A TB EVO 4 IS COMING OUT
*WADE*
shortyzz is offline
Old 12-07-2003, 07:24 PM
  #623
i think i will stay with my EVO2 for a lil while yet
Old 12-08-2003, 02:23 PM
  #624
shortyzz's Avatar
i think i will stay with my TB EVO 2 untill the EVO 4
shortyzz is offline
Old 12-08-2003, 10:54 PM
  #625
shortyzz's Avatar
Default I NEED HELP
hey guys
just one quick questions can u still get (front body mount stay parts # 4035060)for the TB EVO 2 or can u use the TB EVO 3 front body mounts
THANKS
*WADE*
shortyzz is offline
Old 12-09-2003, 01:44 AM
  #626
Default Re: I NEED HELP
Originally posted by shortyzz
hey guys
THANKS
*WADE*
you can use the evo3 body mounts i think.
part number 50909,i think.
Old 12-09-2003, 02:18 AM
  #627
shortyzz's Avatar
thanks for that TRF RACER
*WADE*
shortyzz is offline
Old 01-07-2004, 09:18 PM
  #628
rough512's Avatar
Default Gear Covers
Guys
I just want to share a neat gear cover I made for spur gears. The track where I race is littered with tiny pebbles and I was averaging 1 spur gear / pinion gear in two sessions.
I made this from an old plastic box similar to those used for keeping pills.
I never has a pebble caught in there again with this mounted...
rough512 is offline
Old 01-07-2004, 09:19 PM
  #629
rough512's Avatar
The cover was mounted using a thin bolt from the Tamiya Mini 4wd series. It came with some spacers and a lock nut
rough512 is offline
Old 01-07-2004, 09:21 PM
  #630
rough512's Avatar
I inserted the bolt through a hole in the aluminum motor mount, I countersunk the bolt head so the motor can still be mounted flush
rough512 is offline
