Tamiya TB-Evolution II >
Old 08-22-2003, 04:04 AM
  #601
will the real surikarn please stand up!lol,i definatly no this is not surikarn or as we no him!
trf racer is offline
Old 08-25-2003, 05:22 PM
  #602
fabolousRC's Avatar
nah it's not him...he never really driven tb till evo III came out cuz he was always been a belt drive protege. I hate people who play jokes like that.
fabolousRC is offline
Old 08-26-2003, 02:31 AM
  #603
i know he drove the 414 wen the evo2 was out.
mark reinhard drove the evo2.5.
a evo 2 with 04r suspension arms.
Old 09-02-2003, 12:48 AM
  #604
shortyzz's Avatar
Default Cross Spur Gear Adapter for TB Evo II
hi guys
i would just like to no were i can get a Cross Spur Gear Adapter for TB Evo II and how much in Australia
thanks
shortyzz is offline
Old 09-02-2003, 12:53 AM
  #605
Steevo's Avatar
Check Your PM I have one if you want to buy it.
Steevo
Steevo is offline
Old 09-02-2003, 04:42 AM
  #606
Motorsports00's Avatar
Originally posted by Motorsports00
hey guys,
what would you recommend as a good all round pinion gear for a CORE 10x2? just something to work off????
cmon guys.. can anyone help out?
cheers n beers
will
Motorsports00 is offline
Old 09-02-2003, 04:47 AM
  #607
hey guys,
thanks
will
try a overall ratio of around 7;0.
Old 09-02-2003, 06:59 AM
  #608
TRF race. thanks... bu it means?? wat pinion with a 88 toother..??
thanks
Old 09-02-2003, 07:36 AM
  #609
try about a 36-37.
Old 09-02-2003, 08:47 PM
  #610
thats good for stock.. but i think 10x2 would be set for maybe 29/ 30?? wat do others think??
thanks again
Old 09-03-2003, 01:50 AM
  #611
itll b slow down the straight low.
Old 09-03-2003, 05:05 AM
  #612
TRF racer.. thanks for your advice.
will.
Old 09-19-2003, 04:19 AM
  #613
Default bevel gear stripping
Greetings fellow evo 2tian's,
I have just received my tamiya evo2
and i must say i am very impressed with the car's looks and handling. unfortunately for my past two outings, it seems like my rear bevel gear is stripping. Has anyone of you ever experience this, if so please advice. I'm at my wits how to solve this problem.
Thank you very much in advance.
Daren
Dragoonz09 is offline
Old 09-19-2003, 04:26 AM
  #614
ive never stripped my bevel gears and that was including my 8 double.
try some new ones they might just be a weak manufacturering fault.
are you sure its stripping?
Old 09-19-2003, 06:48 AM
  #615
Default Bevel deformity
Thanks for your reply TRF racer, but it's not exactly stripping but the bevel gear becomes deform. This results in improper meshing between it and the big gear on the ball diff. I'm using a 10T double and running it on full time 4WD. When this phenomenon occurs, usually there will be a grinding noise at the rear gearbox and the car turns into a front wheel drive. Could it be my hard braking at the corners? Thanks again
