Tamiya TB-Evolution II >
Old 05-30-2003, 02:36 AM
  #571
Steevo's Avatar
OK Here's the Specs on my TB Evo II.
FRONT
Camber....................................... -2 Deg
Toe............................................. -1 Deg
Ground Clearance....................... 5.5mm
Droop.......................................... 3mm
Front Drive.................................. One Way Diff
Suspension Mount Spacer.......... Front 1.47mm Rear 0mm
Upper Arm Spacer....................... 0mm
Stabiliser..................................... Yellow
Front width.................................. 186.5mm
DAMPER SETTINGS
Oil............................................... . Tamiya Yellow
Piston.......................................... 2 Hole
Rebound Setting.......................... Medium (Urethane Spacer)
Collar setting............................... 3.6mm
Spring.......................................... Blue
Upper Mounting Position.............. Hole 2 (middle)
Lower Mounting Position.............. Hole 2 (outer position)
REAR
Toe............................................. -2 Deg Rear toe Block Used
Ground Clearance....................... 5 mm
Droop.......................................... 2 mm
Rear Drive.................................. Ball Diff
Suspension Mount Spacer.......... Front 0mm Rear 0mm
Upper Arm Position..................... Hole A (innermost)
Rear width.................................. 188 mm
DAMPER SETTINGS
Collar setting............................... 5.2 mm
Spring.......................................... Yellow
Upper Mounting Position.............. Hole 1 (Innermost)
OTHER
Wheelbase.................................. 258 mm
Weight Distribution...................... Front 46% Rear 54%
Steering....................................... Alloy TB Evo II Ball bearing.
Propeller Shaft............................. Carbon
Tyres............................................ Tamiya Type A
Inserts......................................... Tamiya Medium
Motor........................................... Trinity Monster Stock "Pro"
Spur/Pinion.................................. 88/34
Batteries...................................... Sanyo 3300HV NiMH
ESC.............................................. M-troniks Pro DigiMAX Micro ESC
Body............................................. Protoform Chrysler 300M
Car uses TB Evo II Hard Suspension Arms. No conversion to the TA04 Suspension components has been made.
Bearings have been "Prepped" and Inner shields have been removed.
Standard Phillips Head Screws have been replaced with Stainless Steel Button Head Hex Key Screws.
Please note that this set up works for me and my cars weight, weight distribution etc as well as my driving style and the track I run on.
Good Luck
Steevo
Steevo is offline
Old 05-30-2003, 12:43 PM
  #572
steevo my set up is wot i use for indoors on a wooden polished wood.but gives blinding grip out doors to.
also i only use the standard anti roll bar.
trf racer is offline
Old 06-03-2003, 10:59 PM
  #573
rough512's Avatar
Default TRF RACER
I understan you use TA04 front and rear arms. How do you set the droop with these arms? internal limiters?
I ran with 04 rear arms and I have no droop control whatsoever. I don't have any problems so far but I'm only a novice
rough512 is offline
Old 06-03-2003, 11:23 PM
  #574
Steevo's Avatar
Hi Rough,
I have seen someone with the Ta04 Arms conversion and what they did was turn the arms around and drill new 2.5mm droop holes in the arms with a drill press.
Steevo
Steevo is offline
Old 06-04-2003, 05:44 AM
  #575
iam trf racer but with a differenht user name.
rough 512 i use 04 rear wishbones and 2 degree toe in hubs and 04 front hubs and c hubs but standard evo 2 lower arms.
if u use the full 04 wishbones it lengthens the wheelbase to much as iam racing indoors on a very small track.
trf man is offline
Old 06-09-2003, 11:07 PM
  #576
rough512's Avatar
okay..
I've noticed that I seem to break one hub carrier and strip a knuckle arm every outing... is it possible to replace these two parts with those from other brands?
I hear the losi knuckles are being used to replace tc3 knuckles. just wondering whether this can be done to the TB evo1 or 2 also...
I'm thinking of using the 04/414 racing hub carrier but if there are other tougher parts out there, please post them here...
thanks
rough512 is offline
Old 06-10-2003, 07:20 AM
  #577
rough512 use the hardened 414 carriers.they are carbon reinforced and will be much better.they will go on the evo 1 and 2.
Old 07-01-2003, 02:50 PM
  #578
fabolousRC's Avatar
Default Me and My TB EVO II
Before loss of traction ruined the body :sad:
fabolousRC is offline
Old 07-01-2003, 07:35 PM
  #579
Aluma's Avatar
dude! so thats what you look like....woah... How do you guys manage to get your hair like that? Lots of kids at my school have that hair dew... boggles the mind...
Hey, how's that scoobie body handle compared to the stratus 2.0?
Its the HPI version right?
wow rough512, how in the world do you manage to do that every race.... in the 4months I had my evo2, I only managed to break the original front C hub ...but that was cuz I lent it to someone and he ran into a corner 90 pipe with the front wheel and body off. Try the TA04 racing carrier set. It handles better.
Aluma is offline
Old 07-02-2003, 02:07 PM
  #580
were is everybody?all abandoned ur evo 2?
Old 07-03-2003, 01:29 AM
  #581
rough512's Avatar
My EVO2 is undergoing repairs
I've replaced the front hub carrier with with the ta04 racing hub carrier. I also put back the original rear arms, I previously used rear 04 arms but I don't like losing my droop setting options.
Next thing I'll try is to put in some pivot ball suspension arms and uprights on the rear. I got to see an XRAY upclose and I like the near-no-slop feel of the pivot ball suspension. I wish I could do that to the front.
rough512 is offline
Old 07-05-2003, 07:16 PM
  #582
fabolousRC's Avatar
The scoobie needs more rear down force...the stock wing just wouldn't cut it. I am debuting a new Altima body next weekend and I'm gonna race that car in modified. I'm sick of .4 pitch gears (they're too soft) so I'm gonna switch back to the .6 spurs either my fave combination 25/61 (it's a big track) or 23/58. E2 is so much pain in the behind to tear apart that I'm ready to shelf it as soon as I get more $$$ to get the E3.
For the time being, I'm gonna tear my front gearbox apart and install a gear diff instead. It's either the combination of that I set the brake potentio too high (full force to be exact) or losing grip because of the one way...the car is just too nervous for the whole race.
Old 07-13-2003, 12:05 PM
  #583
fabolousRC's Avatar
Thumbs down
The stupid screws stripped the race before last night so I ended up retiring the TB EVO forever (unless I can find a replacement soon enough ). I ended up running my TC3s
Old 07-13-2003, 11:49 PM
  #584
Motorsports00's Avatar
Default ATTN STEEVO
hey steevo, since PM and Email is turned off, i need to contact you RE TB Evo2, desperatelly,
please email to [email protected]
thanks mate
cheers
will
0422 028 143
Motorsports00 is offline
Old 07-22-2003, 07:41 AM
  #585
thanks for your help.. its okay i already have spoken to steevo.... btw i ended up buying another evo2 today as SPARES!!!
haha
cheers
will
