Tamiya TB-Evolution II >
Old 04-27-2003, 08:42 PM
  #556
Steevo's Avatar
Hi Rough,
If thats you in your Avatar well your one cool looking dude
I have made a few set up changes to my car during the week but haven't been able to test it because of constant rain over the last few days
As soon as I get a chance to test it I'll let you know how it goes..
I actually prefer my TB EvoII to my Xray!!!
Its one sweet ride and no stripped front one way gears like the newer model
Steevo
Steevo is offline
Old 04-29-2003, 09:16 PM
  #557
Motorsports00's Avatar
Default built new evo 2 for sale
for anybody out there ( racer or collector) i have an EVO2 for sale in mint condition.. onli has been run on my carpet for a test n has sat on my shelf for the rest of the time. i paid $700 AUD as new and have built it and painted a tamiya ferrari body on it. Radio/ electronics not included. PM me for pics and details
cheers will
Motorsports00 is offline
Old 05-14-2003, 06:43 PM
  #558
Default PARTS!
anyone know where and which adjustable turnbuckles i can get that will fit on my EVO2??? please if u can provide with a brand and part #.. i would appreciate it.
Cheers
will
Old 05-15-2003, 06:23 AM
  #559
Aluma's Avatar
go white tamiya front/ blue tamiya rear springs... Its what i used to run on my evo2 when i used to race it on bumpy outdoor asphalt. Its fast! and oversteers just purrfectly around the corners if you got a front diff.
Aluma is offline
Old 05-26-2003, 12:49 AM
  #560
fabolousRC's Avatar
Default UPDATE
I just got the Spur Gear adaptor for F201 over the weekend and unfortunately without a mere dremel modification (which I don't have), it will not fit TB EVo II
fabolousRC is offline
Old 05-26-2003, 12:55 AM
  #561
Steevo's Avatar
What sort of Mod does it need fabulous??
Steevo
Steevo is offline
Old 05-26-2003, 06:24 AM
  #562
Default MOD
hey guys, wat spur /rollout would u use ( with 88 spur) for a 10 x 2 mod motor.. i was told a 30 tooth.. wat u think??
thanks
will
Old 05-29-2003, 02:44 AM
  #563
fabolousRC's Avatar
Steevo
I need to take out some material at least to where the spur gear hub meets the pin on the driveshaft. Otherwise, the rear gearbox would sit right on its place nor the drivetrain be free.
Old 05-29-2003, 02:52 AM
  #564
Steevo's Avatar
OK I see.
Actually I have just ordered a Cross Spur Gear adapter for the TB-01.
I am hoping it will work with the TB Evo II. I have heard that it will..
Steevo
Steevo is offline
Old 05-29-2003, 11:33 AM
  #565
best evo 2 set up. put tao4 wishbone and hubs all round.2 degree rear hubs from the ta04
than on the front;
red springs
30 w shock oil
inner mount on wishbones for shocks
inner most hole on damer sty for the dampers
1 degree - camber
0 degrees kick up
rear;
yellow springs
30 w shock oil
inner mount on wisbone for shocks
inner most hole on damper stay for dampers
1 degree-camber
0 degree
0 degrees anti squat
upper arm on lower mount on hub
i also took the front and middle chassis braces off
use front diff.
this is a very good set up
trf racer is offline
Old 05-29-2003, 02:44 PM
  #566
Steevo's Avatar
than on the front;
red springs
30 w shock oil
1 degree - camber
0 degrees kick up
rear;
yellow springs
30 w shock oil
1 degree-camber
0 degree
use front diff.
On what surface do you run this set up on.
Steevo
Steevo is offline
Old 05-29-2003, 03:22 PM
  #567
eeyan's Avatar
OK I see.
Steevo
Yup, the Cross adaptor will work perfectly on the evo 2... but you may want to shim the shaft for better play though or the spur will wobble a bit...
eeyan is offline
Old 05-29-2003, 06:13 PM
  #568
Whats the Internal ratio for a tamiya Evo2, and a TA04??
Besercoe is offline
Old 05-29-2003, 06:42 PM
  #569
rough512's Avatar
than on the front;
red springs
30 w shock oil
1 degree - camber
0 degrees kick up
rear;
yellow springs
30 w shock oil
1 degree-camber
0 degree
use front diff.
I'm also curious whether this would work on a bumpy track.
I used to run red springs all around; I used graphite EVO arms in front and shaved TA04arms/2deg. rear hub. I was thinking that the soft srpings will make the car track better over the bumps. I also thought the soft front springs + front one way = more roll, better steering.
At that time, I was working on MCrisp's advice : Softer front springs + less front droop = more on power steering. Your setup setup reflects this very theory and I was a stout believer of it
Then I tried swapping in a yellow spring in front, red springs at the rear. I got more steering. I'm started to get confused. I swapped the red front springs and immediately found it less satisfying.
I'm working on this style of driving:
When I approach a corner at higher speed, I decrease throttle at about 1 ft away from the corner ( to transfer some weight in front) then start to steer. IMO this would give me more traction for steering. On mid Corner, I start to gradually increase speed. I try to accelerate hard without going too wide. Once I punched hard on throttle at mid corner and the car drifted just enough to line itself out of the corner. I like it.
There is a part in the track where a wide 180deg turn is followed by a tight hairpin. On the hairpin, I found that I can put 100% throttle and still follow a tight line with the EVO2. This happens with RED/YELLOW front and RED rear springs. With my old TA03, I had to apply 50% throttle on this part. I think this is where the front one way really comes to play. I haven't tried this with a spool.
rough512 is offline
Old 05-29-2003, 07:14 PM
  #570
Steevo's Avatar
Thanks for the confirmation eeyan. I should get it early next week. I look forward to using standard 48 pitch Spurs and Pinions
Rough512, I will post the set up I am using on a Parking Lot track soon.
It is reasonably smooth but is mostly unprepped so there are tiny pebbles which don't cause much problem, especially now that I have made a cowl for the Spur/ pinion area that keeps 95% of the dirt out of the gear area.
Steevo
Steevo is offline
