Tamiya TB-Evolution II >
Old 12-02-2002, 08:45 AM
  #466
Trader Rating: 24 (100%+)
Talking
Hey AQ,
I'm no genious and I'm no superstar driver but , Who told you not to run a 88 t spur?? That is the stock spur setup. I ran mine with a 34t pinion( supplied as stock with kit) and found it to slow on the straight. Went to a 36t and YEAH MAN !!! She was zoomin' and had no problem coming out of the turns. I run a Putnam GM3 stock motor. Don't know how big your track is but try that and see what happens. Good Luck.
Evoracer is offline
Old 12-02-2002, 11:33 AM
  #467
Aluma's Avatar
hey guys, how do you gear for a 11T or 12T motor using an 88 spur or a 55spur? how fast would this thing be with that type of motor? I just run stock so I'm new to the mod stuff.
Aluma is offline
Old 12-03-2002, 08:45 PM
  #468
Trader Rating: 17 (100%+)
Talking TB Evo2 setup
Anyone race at SoCal RC raceway? I think I got like the most expensive car in rookie class. lol. I was just wondering who might have a good setup for a TB Evo2 for SoCal. I want to join the SoCal GP, but I dunno if I can, since it's so far. I live in San Diego. Plus, anyone know where the sell the Spur gear adaptor for the TB Evo2?? I heard from the Evo3 thread that they sell them. If they do, where can I get it? If you're going to SoCal, can u get it for me?? That'll give me a good reason to come up there :-D. I'm just looking for aftermarket parts for my evo2. Hey does anyone know if the Tamiya Track at Alisio Viejo sells parts? Thanks. PEOPLE HELP ME IN MAKING MY EVO2 FAST FOR SOCAL!! HEHEH THANKS EVERYONE
AQuionIV is offline
Old 12-04-2002, 02:10 PM
  #469
www,rcmodel.com.hk search for tb-01 they have the TOBEE craft one I just ordered mine.
sportracer is offline
Old 12-04-2002, 04:33 PM
  #470
cool website....thanks sportracer
Evoracer is offline
Old 12-04-2002, 04:36 PM
  #471
rc-zombies's Avatar
RcModel...best place to order option parts not found in the US.
rc-zombies is offline
Old 12-20-2002, 06:50 AM
  #472
rough512's Avatar
Default Re: difference between tb evo 1 and 2?
Originally posted by azDan
Hey guys I just sold my xxx-s and am looking to get a TB Evo. What is the difference between the evo 1 and the evo 2? I saw some evo 1's up for sale on ebay and the message boards but thought I'd ask the you all since your the experts.
Dan
Any more inputs? How much does the original Evo1 give up in terms of performance/adjustability? What components are shared? Are the gear boxes the same with either car?
Do you think it's worth sticking with older car or do I just start looking at the TA04?
rough512 is offline
Old 12-20-2002, 07:26 AM
  #473
Default Re: Re: difference between tb evo 1 and 2?
The original evo1 is heavier than the evo3 so that would have some effect on performance. It can be hopped up to reduce weight by using titanium turnbuckles and screws.
As for adjustability, I would say it is still fairly similar to the Evo3.
The Evo1 does not use Ta04 arms and uses a proprietory spur gear. You can however get an adapter to fit normal spurs.
itchynads is offline
Old 12-20-2002, 07:27 AM
  #474
Don't forget Rainbowten.co.jp, although ordering is a bit more insecure
They are very reliable and are always very patient with their customers.
They also have the best prices for Tamiya parts and usually get latest released parts earlier than anywhere else.
Old 12-20-2002, 11:23 AM
  #475
rough512,
Subtle differences between the Evo 1 and Evo 2. Evo1 has upper control arms, evo2 doesn't. Basically the same car. Personally, i'd find a Evo2 . There is one for sale in the classified section. Look for seller name TRF_powered. 170.00 bucks. Good deal. If you don't make a deal there, let me know..I have a friend who has one new in box.
Evoracer is offline
Old 12-21-2002, 02:59 AM
  #476
fabolousRC's Avatar
Default spur gear adaptor
I'm wondering guys...my LHS has the spur gear adaptor for the F201 and I WOULD LOVEEEEEEEEEEEE to use that for my TB01 project. It sure does look it is missing some critical part in between the spur gear and the rear gearbox or the main shaft holder. I'm just afraid that gorgeous aluminum holder will not keep the spur gear in place, drop that tiny pin in the middle, and my car ended up going nowhere.
fabolousRC is offline
Old 12-22-2002, 06:41 PM
  #477
rough512's Avatar
rough512,
Thanks, but I have to pass
I already started tinkering with the 2nd hand TB EVO1 I got. Except for a bad pinion bevel gear, the car looks great. Only ran it in our living room. Compared to my TA03R, the EVO1 seems to push a bit where the TA03R would 2wheel-drift on sharp U turns. Can't wait to test it on our local track.
From the pictures of the EVO2 posted here, the only difference I can see between the EVO1 and EVO2 lies on the bulkheads and camber links. I've also read the posts of RUF and Aluma on how the EVO2 being difficult to dial in. I hope the EVO1 is better . I could see some problems with the EVO1 camber links being stuck on only one position.
rough512 is offline
Old 12-22-2002, 06:55 PM
  #478
Can't vouch for the EVO 2 being hard to dial in.....Just spent the day winning all 3 qualifiers and the A main. I Love This Car!!
Define "camber links stuck in one position" . Do you mean the connection point to the hub?? Or are you thinking that the camber is not adjustable??
Evoracer is offline
Old 12-22-2002, 07:17 PM
  #479
rough512's Avatar
THere is only one inner mounting point for the upper arm. That is on the bulkhead itself.
I understand that with the EVO2, the inner end of the camber link can be adjusted higher or lower ala 414M. My EVO1 upper arms are all angled down towards the chassis.
rough512 is offline
Old 12-22-2002, 10:48 PM
  #480
fabolousRC's Avatar
On the Evo I you can re-position the camber link like where the EVO II is an just move away from that fix arm altogether. The problem is, if you run TCS race, it's not going to be legal if they found out it's a TB Evo I not the II.
