Tamiya TB-Evolution II >
Old 07-13-2002, 12:02 PM
  #301
Ooh I forgot to ask wheres the cheapest shop to get a Tamya TB evolution 2?
Thanks again
Dan
azDan is offline
Old 07-13-2002, 08:27 PM
  #302
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
THe EVO2 is alot stiffer from left to right. THe EVO1 is very easy to tweak. I have the EVO2 and raced it again tonight and destroyed them tonight. WIth my new Stratus on I went 4 seconds faster and lapped everyone in the main. THe car is on rails and has been a great car for me. I like the car because when I do little adjustments on the car they actually do something.
wyd is offline
Old 07-13-2002, 08:29 PM
  #303
wyd
Tech Legend
wyd's Avatar
I see EVO2's on EBAY brand new in the box for $263. That is a great price. I tempted to get a 2nd one for a spare even though it has not broke at all.
wyd is offline
Old 07-14-2002, 05:29 AM
  #304
AsiaTees's Avatar
Any one here will be interested in some GPM Tamiya TB series alloy hop-ups? We now have them in stock now at a very very good price.
Thanks! ! !
Asia Tees.com
AsiaTees is offline
Old 07-14-2002, 05:47 AM
  #305
sonneteer's Avatar
I think the main thing different is with the EvoII you can change your gearing with not much cursing!
other than that I believe the suspension set up are a little different according to a mag review over here.
sonneteer is offline
Old 07-16-2002, 12:55 PM
  #306
I purchased some Ta04 universals for my TB01 with long suspension arms kit and ran into a problem. The hubs on the LSA kit take 6x12mm bearings but, the Ta04 universals are for 5x11mm bearings and needlesss to say, it's too loose. If 5x12 mm bearings existed, this wouldnt be a problem. On the pack it says for Ta04, 414 and TB Evo 2 but, the LSA kit is Evo arms and hubs etc. What's wrong? Are TB Evo 1 and 2 hubs sizes different?
x414x is offline
Old 07-17-2002, 10:38 PM
  #307
fabolousRC's Avatar
WOW!! Ok..I'm getting a TB Evo 2 on my next next paycheck!!!
fabolousRC is offline
Old 07-17-2002, 10:48 PM
  #308
dtm
dtm's Avatar
You still curse a lot more than your average 2 belt car...but I know what you mean!!
dtm is offline
Old 07-17-2002, 10:58 PM
  #309
TRF-Powered's Avatar
well, it kinda depends on what kinda spur you are running... if you are running a 88t, changing the spur doesn't make any different from the EvoI... if you are using 72T... hella easier!!
TRF-Powered is offline
Old 07-18-2002, 04:13 AM
  #310
dtm
dtm's Avatar
Why is it easier?? you still have to remove the rear gearbox and pull the shaft out from the back??
dtm is offline
Old 07-18-2002, 04:11 PM
  #311
wyd
Tech Legend
wyd's Avatar
I think it is easier to adjust the motor. Spur gear removal is about the same. It don't take too long to do. Takes me 5 minutes or less to change the spur if I need to. Never needed to change from the stock 88 yet as it has not stipped at all. Take a little time meshing it and it is fine. Hitting the walls don't help the spurs too much either.
wyd is offline
Old 07-19-2002, 04:10 AM
  #312
I read a while back that somebody amde a spur gear adapter for the EVO's who ,where and how much.
sportracer is offline
Old 07-19-2002, 10:28 AM
  #313
dtm
dtm's Avatar
errrr..... help yourself...try scrolling down the thread!! you didn't read it that long ago!!
dtm is offline
Old 07-23-2002, 05:07 AM
  #314
wyd
Tech Legend
wyd's Avatar
Does Tamiya or any other company make alum. rear hub carriers and alum. front caster blocks that fit the EVO2. I don't have any problems with my stock ones but it would be trick to have.
Would TA04 ones possible fit or maybe ones for the 414M2.
Brian
wyd is offline
Old 07-23-2002, 05:18 AM
  #315
For the front, it would work, the back would not.
x414x is offline
