One Way Maintanence >
One Way Maintanence
One Way Maintanence
Old 10-23-2003, 03:01 PM
Rod M's Avatar
Default One Way Maintanence
a few months ago I put a front one way in my TA04,
since then I have not really touched it,
is there any sort of regular maintanence that needs to be carried out to keep it in good working order?
thanks
Rod M is offline
Old 10-23-2003, 04:16 PM
RA99GT's Avatar
just keep the 1-way bearings properly greased, i guess
RA99GT is offline
Old 10-23-2003, 07:35 PM
Rod M's Avatar
would ball diff grease be suitable?
Rod M is offline
Old 10-23-2003, 07:37 PM
Neil Rabara's Avatar
Default Re: One Way Maintanence
thanks
I'm sorry I don't have an answer to your question. I got distracted by your......................avatar.
Neil Rabara is offline
Old 10-23-2003, 07:42 PM
Carbon_Fibre3's Avatar
Hi Rod, in the xray thread we have been talkin about this very thing (some time bak though) the arguement was put forward that some lubes would be to slippery and cause teh one ways to slip.. or the outdrives to slip in the bearings themselves (i didnt understand what they were getting at.. oh well)
but i use associated stealth diff lube, and have never had a problem with slippage ..
so i think ur ball diff grease shoudl be fine. the main thing i do is make sure they are cleaned out every now and then to make sure no dust and junk can clog and for tehm to seize..
Rob Storey
Carbon_Fibre3 is offline
Old 10-23-2003, 07:58 PM
Aurra Sing's Avatar
For the TA04 one-way, you do not need grease the bearings. I had ran one without grease for over 1.5 years. If it gets dirty, I spray the bearings with motor spray and re oil with bearing oil.
Aurra Sing is offline
Old 10-23-2003, 08:23 PM
S-T-R-l-K-E-R's Avatar
one of my buddies got this one way lube. its designed for one way diffs. is supposed to protect and make your one way perform better. i think you should check it out.
S-T-R-l-K-E-R is offline
Old 10-23-2003, 08:50 PM
Registered User
Calvin Ng's Avatar
Default Re: Re: One Way Maintanence
2 on that
Calvin Ng is offline
Old 10-23-2003, 09:09 PM
Intermision's Avatar
there was a question, where?
Intermision is offline
Old 10-23-2003, 10:00 PM
Registered User
Calvin Ng's Avatar
sometimes kids parents come around looking at what there doing on the comp.... and they ask what the heck that is..
example is me
Old 10-24-2003, 05:11 AM
Cole Trickle's Avatar
I've raced with a HPI one-way pulley for 1 year - never maintained it at all, and it still perform well.
HPI one-way diff: From time to time, I clean it for carpet dust and grease it with HPI one-way grease. This also works well.
Case is, that the HPI diff is more open, than the HPI pulley, which is well protected.
Cole Trickle is offline
Old 10-24-2003, 03:28 PM
Registered User
Calvin Ng's Avatar
i herd you werent suppose to put grease into one-ways
slow is down
Old 10-24-2003, 03:31 PM
holycow's Avatar
I always come in and try and help Rod out when he has questions, but I NEVER seem to get to an answer.. . I wonder why?
holycow is offline
Old 10-24-2003, 09:48 PM
you can run one way grease if you want, or you can run it dry, either way is fine i guess. but i wouldn't think diff grease would do the job really, a specific one-way grease is what's needed. i personally run mine dry without any problems. either way you should spray it out every now and then, but other than that, no maintenance is needed (for the average racer anyway).
now, back to that avatar...
Rory is offline
Old 10-24-2003, 10:22 PM
Maj. Teeth's Avatar
Here's what I do. Blow it our cleanly with motor spray and lightly put a drop of two of royal oil and insert the diff cups and spin it for awhile and it's back in business and very smooth.
Dan
Maj. Teeth is offline
