Old 01-05-2009, 10:39 AM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Default Novak ESC question?????
Can you use a different brand motor (sensored) with the Novak brushless ESC? please explain
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 01-05-2009, 10:52 AM   #2
The Evicerator
With most of our ESCs this is possible, but with certain ESCs there are software checks that inadvertantly prevent some other brands' motors from being run.
This stems from the fact that most other manufacturers fail to include an onboard temperature sensor for the motor. Some of our ESCs run checks to ensure that the temperature sensing for the motor is active (IE, temp sensor wire has not been cut, etc) to ensure safe running conditions. If the motor temperature sensor is not present, some of our ESCs will not power up and run the motor.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-05-2009, 12:53 PM   #3
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
I have used Novak, Trinity, and Speed Passions motors with my GTB with no problems. I'm pretty sure that most of the name brand motors will work with the GTB. Ones like the Mambas won't. I think Hacker works with the GTB as well but i could be wrong.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 01-05-2009, 01:34 PM   #4
The Evicerator
Most of the sensored motors should run fine with the GTB!
Steve Weiss
Old 01-05-2009, 03:09 PM   #5
Sounds like your employeed by Novak. I have heard that you can run some other brands with the GTB, but I have the XBR Esc and looking for a little more performance. Would it be better to run a 8.5 w/sinter rotor like the NOV3408
http://www.amainhobbies.com/product_...ducts_id/12846
I just don't want to pay $80 for just a motor, seems a little steep. Any other advice. I like the feel of the 8.5 just needs a little more torque.
Old 01-05-2009, 04:23 PM   #6
The Evicerator
Mike,
You're right I am employed at Novak.
Your easiest (and cheapest) solution is to get a sintered rotor upgrade kit for your motor. This will upgrade your motor to near "pro-spec"... basically the only thing it will be lacking will be the ribbed/lightened endbells... but there is not major performance difference in the two types of endbells.
If you go online to our shopatron website you can get the upgrade kit... the part number is S5923.
Hope this helps!
Steve Weiss
Old 01-05-2009, 08:24 PM   #7
Steve, I feel like an idiot....I did not see your signature. Thanks for the info and were can i purchase that upgrade other than the shopatron? I like to use paypal. I did not see it on amains website.
Old 01-05-2009, 11:30 PM   #8
The Evicerator
unfortunately that kit has been discontinued from general distribution... you *may* be able to find it elsewhere like tower or horizon...but otherwise if you don't like shopatron you will have to part it out with the sintered rotor and large bearing front end bell
Steve Weiss
Old 01-06-2009, 12:16 AM   #9
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Gtb
I have a Hacker 17.5 running fine off a GTB.
Jaz406 is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
Novak GTB with no Lipo-Cutoff ??? xman Electric On-Road 20 01-19-2009 08:51 AM
Novak GTX esc For Sale! YokomoMR4BX R/C Items: For Sale/Trade 13 05-10-2007 09:06 PM
Is This A Good ESC? tmeeks Electric On-Road 6 03-13-2004 10:02 PM
