Old 01-03-2009, 02:15 PM   #1
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default Light vs. balanced?!?
Hey guys, I just finished building my TC5 and RTR without the body, pins and transponder it is obviously heavier on the electronics side. My question is should I add weight to balance the car side to side or not add any and keep the car as light as possible. I have a Spektrum sr3000, GTX esc, 27t brushed motor, and a digital Airtronics servo on the drivers side and run Orion 2s 3200mah LiPos on the right.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 01-03-2009, 02:18 PM   #2
Trader Rating: 38 (100%+)
Balanced. It needs to be brought to weight to race most places (1500g from rubber tire) anway.
or8ital is offline   Reply With Quote
Old 01-03-2009, 02:20 PM   #3
miller tyme's Avatar
With the Lipo, brushed and those electronics, it most likely is not a lead sled. I'd go ahead and add weight to the far outboard side of the Lipo to balance it out. Or depending on the amount of space move the Rx and Transponder to the light side.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-03-2009, 02:20 PM   #4
sportpak's Avatar
Trader Rating: 26 (100%+)
It needs to be reasonable close on the balance if the things ever gonna be consistent.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-03-2009, 02:35 PM   #5
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Originally Posted by or8ital View Post
Balanced. It needs to be brought to weight to race most places (1525g from rubber tire) anway.
ROAR min weight is now 1500g...your club may vary
-rocky b
flatspunout is offline   Reply With Quote
Old 01-03-2009, 02:42 PM   #6
Balanced. I personally think that the whole lightweight thing is overrated. It is now to the point with all these ultra high tech alloys that you can easily spend 200 bucks on light weight parts though out your car only to find out that you can not make weight and then you are tossing on 2 dollar pieces of lead to the car to make weight. A balanced car that drives without surprises and that is predictable is 100x better than a really light car. Take a look around the pits where top racers are and you will see them with enough lead on their cars to sink a battleship, all of this is strategically placed to balance the car.
Tony
under200 is offline   Reply With Quote
Old 01-03-2009, 03:04 PM   #7
-rocky b
yeah i guess it is Jan aleady
Old 01-03-2009, 03:04 PM   #8
British Menace's Avatar
I think it comes down to priorities.
If you are racing in a race that is being run to race rules, weather club rules or ROAR. You must make the regulations.
It does not matter if you have a perfectly balanced car, 1000 dollars on lightweight parts or whatever. You need to be legal!
If you are racing at a venue which is not running under specific rules or "light" rules such as Tires, Motor and battery only. The get the balance right and don't worry about the weight!
You must have a car that is legal FIRST then everything else comes after!!
If weight is not a problem. Then the amount of weight needed to get balanced will not make a noticable difference to performance. So get balanced !
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 01-03-2009, 03:22 PM   #9
Regards,
British Menace
Agreed balanced is necessary but the weight to get it balanced is significant to performance. Its amazing how much faster a 100g lighter car is.
Old 01-03-2009, 03:22 PM   #10
trdsupra88's Avatar
Thanks for all the responses. There are no rules for weight where I race. I prefer to have the car predictable so I will add some weight to the car. There are to empty spot in front and behind the battery where I can add. thanks again for the input.
I cut my own hair ☆
Old 01-04-2009, 07:35 PM   #11
trdsupra88's Avatar
I added some stick on weights and ended up putting on 6.5 ounces. How much are you guys putting on?
I cut my own hair ☆
Old 01-04-2009, 08:24 PM   #12
5.5 on a tc5 using these:
http://www.ppdbillet.com/RC_accessories.html
if I raced at a place without a weight rule I would either ask for a weight rule or get a Losi Type-R
Old 01-04-2009, 09:04 PM   #13
trdsupra88's Avatar
Hey thanks again. I may get that and take all the random lead weights I have on the batter side...
I cut my own hair ☆
Old 01-05-2009, 06:45 AM   #14
Balanced.
I like light weight.. but until new tires come out that take advantage of a lighter lipo car that has no lead weight, I'll have to defer to balanced.
Sabin is offline   Reply With Quote
Old 01-05-2009, 08:58 AM   #15
markf3x's Avatar
Unless against some local rules, my preference would be a larger battery to help balance out the car (will not only require less lead to balance, but will be faster).
On the other hand this isn't a $1 solution like adding some lead.
markf3x is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46191 Today 07:43 AM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Indoor Carpet Racing @ RC Performance in Madison Associated-08 Wisconsin & Illinois Racing 3426 11-25-2010 04:03 PM
Slash vs SC10 vs Strike Wee-EDM Electric Off-Road 61 06-21-2010 09:15 PM
Balanced Chassis vs Minimum Weight Teehomo Electric On-Road 10 02-24-2009 06:25 AM
belt vs shaft Quietroit Nitro On-Road 112 07-14-2004 02:40 PM
