Old 10-23-2003, 10:53 AM   #16
Registered User
OB42TC3's Avatar
OK;
I was wondering because it would probably work even better in an ultrasonic cleaner like the integy. That really shakes a lot of crap out, even the carpet dingleberries. No shields at all? I might have to try that. Right now I really like the metal shielded ones from Losi in my TC3, because they are very low friction (not contact) and I put the side of the cage that's closed towards the outside and that combined with the shield makes a pretty barrier against the carpet. I still defuzz the axle whenever I can, but this is the best I've tried so far.
OB42TC3 is offline   Reply With Quote
Old 10-23-2003, 03:46 PM   #17
Joel Lagace's Avatar
Originally posted by g4t2
Joel, there is no reason why the shields should be damaged when you remove them, I've never damaged one before, just make just you are gentle with them and it should be fine.
They are damaged by the time i get them out.LOL Keep in mind that not all shields are teflon material, some are metal others are rubber.
But for all the effort involved with removing and then trying to re-install them i just leave one side off all the time. And clean the bearings when needed. Flush soak dry and oil.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-23-2003, 03:48 PM   #18
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
so you guyz just leave one side of the bearing open all the time?
Calvin Ng is offline   Reply With Quote
Old 10-23-2003, 03:56 PM   #19
speedxl's Avatar
R/C Tech Charter Subscriber
yes calvin just put the bearing with the shield outside and the open side torwards the inside.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 10-23-2003, 04:01 PM   #20
Exclamation
or u can do it the simple way and buy a set of acer ceramic bearings the require no cleaning at at !!!
snoboardin is offline   Reply With Quote
Old 10-23-2003, 04:05 PM   #21
Registered User
Calvin Ng's Avatar
no grease no nothing?
Old 10-23-2003, 04:07 PM   #22
why do they need no cleaning?
mark turner is offline   Reply With Quote
Old 10-23-2003, 04:11 PM   #23
speedxl's Avatar
you still need to clean them and oil them just not as much plus they are expensive and are very sensitive to impacts thats why we only use them at big races for the xtra zip!
Old 10-23-2003, 04:17 PM   #24
Would you still take the seals out to clean them?
Old 10-23-2003, 04:21 PM   #25
speedxl's Avatar
yes i do it to all bearing regardless.
ecxept for the offroad stuff. !thats obvious!
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 10:34 PM
Ceramic Bearing VS Normal Bearing MRX_joe21 Nitro On-Road 25 11-19-2005 11:09 PM
One way bearing gone...again! silacomalley Monster Trucks 6 10-03-2005 05:07 AM
Bearing. tkhoo Malaysian R/C Racers 16 01-28-2004 10:54 AM
One Way Maintanence Rod M Electric On-Road 15 10-25-2003 02:25 AM
