Losi XXXS chassis milling? >
Old 10-21-2003, 08:02 AM
Default Losi XXXS chassis milling?
HAs anyone milled there XXXS chassis with extra cutouts? If so whats the best way to do it?
James VanHook is offline
Old 10-21-2003, 08:15 AM
Andrew Gray's Avatar
I'm not sure why you want more cuttouts in your chassis, but if you wanna do it, use a dremel with a carbide cutting bit, and cut some material out of the tunnel. A dremel is really the only thing to use because the way the chassis is you cannot put it in a jig to use a mill... Hope this steers you in the right direction.
Andrew Gray is offline
Old 10-21-2003, 08:33 AM
Regional Moderator
I just did a G+ chassis and i used a drill press with a rotuer bit on it and i used a tool for fine detail work . works something like a dremel but a much larger scale i use this tool alot for cermic tile work i do.
but here is a photo of what i did and its for sale also
Ko Racer is offline
Old 10-21-2003, 08:41 AM
KO- yeah I saw that yous car was for sale and how sweet it looked. Thats why I asked how to do it. I know Kinwald did it a while back so I thought I would take the chassis that came with the original car and play with cutting it out. I mean what am I going to do with at plastic chassis when my car is all graphite. By the way, that can is so tight with the white ball cups. I want some! LOL
Old 10-21-2003, 08:50 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
You can also do it with a dremel... I did, but it takes a TON of time (6 hours for mine) and it's much easier to mess up with a dremel.
Randy Caster is offline
