Old 12-31-2008, 07:28 PM   #1
Default Spektrum Reciever Incompatabiliy?
I have a problem with a Spectrum DX3S reciever SR300 connected to a GV Electronic Speed Control, has anyone encountered this before?
Reciever is working fine when connected to servo throttle in nitro car.
danno81 is offline   Reply With Quote
Old 12-31-2008, 08:58 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Can you describe the problem? What specifically is happening (or not happening) when it attached to the speed control?
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-31-2008, 10:01 PM   #3
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Check the BEC output of the speedo...if it is less than 6v you may need to run the spektrum booster cap. It plugs into an open receiver port and basically stores an extra volt for the receiver if I understand correctly how it works.
-rocky b
flatspunout is offline   Reply With Quote
Old 12-31-2008, 10:09 PM   #4
the light on the ESC is flashing and the throttle not operating. The steering servo is working fine. We swapped the steering servo to throttle on reciever and the throttle controlled the steering. Then we fitted reciever to a nitro car
and both throttle and steering worked fine. Back on electric car throttle wont work.
Old 12-31-2008, 10:13 PM   #5
Regional Moderator
CarbonJoe's Avatar
Did you setup the speedo with the radio? In other words, is the speedo calibrated to full throttle, brake, and neutral? Most speedos won't work correctly until they are setup to the radio's throttle travel "endpoints".
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-31-2008, 10:17 PM   #6
Just checked the voltage and it's 4.95V will have to get booster Cap and give it ago. Thanks for your help
Old 12-31-2008, 10:59 PM   #7
Trips's Avatar
danno,
hold off on that booster cap. Your receiver should work just fine at 4.9 volts. The fact that the steering servo is working means that the receiver is working.
This is what I'd check, in this order:
1. As Carbon Joe said, make sure the speed control is calibrated. Follow the calibration steps in the speed control manual. That ought to get you going if you haven't already done that.
2. I'm not familiar with the speed control you mentioned, so if step 1 doesn't fix your issue try reversing your throttle channel in the transmitter and repeat step 1. Some speed controls expect the throttle signal to be in a certain "direction" before they'll accept calibration.
3. If still not working, go into the radio end point adjustments for the throttle channel and make sure the endpoints for throttle and brake are set to the max. Then repeat step 1 and if necessary, step 2 again.
4. If you're still not up and running, check the plug from the speed control that goes into the receiver. one of the little terminals in the plug may not be fully seated, and that will prevent the speed control from getting signal from the receiver. The terminal you're concerned with is the one furthest from the edge of the receiver case when plugged in. That';s the terminal for the signal wire. The other two should be fine, or you'd get no lights on the speed control, and no steering. While you're at it, make sure the wire from the speed control to the plug for the receiver is intact... if the signal wire is cut or broken, the speed control will power up and you'll get steering, but no response from the speed control. Again, the "signal" wire is in most cases the one furthest from the edge of the receiver case when plugged in. I won't ask you to make sure the plug from the speed control is not in backwards, if it was you would get no lights at all and no steering.
5. I'm out of ideas at this point.
Hope that helps, let us know.
MARSHAL!!
