Old 01-01-2009, 07:24 AM   #16
cyclone speed's Avatar
OK , i will try everythig but i dont get if i should linear discharge or pulse discharge the pack , i will linear discharge to se the difference .
An off topic Q , whats the amp draw of a 3.5 ?
cyclone speed is offline   Reply With Quote
Old 01-01-2009, 07:38 AM   #17
Trips's Avatar
Trader Rating: 16 (100%+)
If you're getting to the track and there is some storage charge in the pack, I would pulse in the tray. If it's right after a run and the car didn't slow down, I'd pulse then too.
Right before the charge, I'd linear in the tray.
In other words, an empty pack, that you're going to equalize just before charging, go linear. A pack with some charge in it, left over from a run, or from storage, go pulse.
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-01-2009, 11:10 AM   #18
OK , thanks for all your help trips , i will cycle the packs and will let you know , thanks again.
Old 01-01-2009, 11:22 AM   #19
SWTour's Avatar
something I never saw asked or addressed is
WHAT Type of racing? What type of car? Type of track? Have you ever raced before?
You mentioned you will be running 3.5 MOD and I believe I read 5 cell...
if you've never raced before, and are jumping in with these batteries and a 3.5 motor...worrying about the amp draw and battery life will probably be the LEAST of your worries...getting the CAR Hooked up and learniing to drive will probably be much more important.
if you are running road course, and geared properly, those batteries should work great for racing.... a 3.5 brushless motor with 5 cell will turn around 63,000 rpm with no load....and close to 32,000 under race conditions loaded... so HOLD ON.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 01-01-2009, 01:16 PM   #20
Joel Lagace's Avatar
Originally Posted by |JayFlores|2 View Post
this is what i used to do with my sub-c's since i am also using ctx cell master and ctx-d2 before
from storage:
1.) pulse discharge down to 1.00v per cell
2.) linear discharge down to 0.9v per cell
3.) rest the pack until its back to room temperature.
4.) charge @ 5amps with 05mv delta settings (adjust depending on the cells peak temp. it should be around 125-130degF)
5.) RUN THE PACK!
from the run:
1.) pulse discharge down to 0.9v per cell
2.) rest for atleast 1hour
3.) linear discharge down to 0.9v per cell
4.) charge @ 5 or 6amps with 05mv delta settings (adjust depending on the cells peak temp. it should be around 125-130degF)
**packs i used, IB4600.
-peaks around 5100mah (after 3months of use.)
-peaks around 4700-4800 (after the 3rd month.)
Just always make sure that after using the pack, put a partial charge in it. around 15-20minutes of charge time and check them after 3-4days for voltage drop in your ctx-d2.
Enjoy LIPO hahaha! kidding
BLABLABLA BLA BLA BLA BLA.... Too much work LOL
I dont miss the crap at all!! LIPO for life! Or untill we exploit them the way we did nicad and nihms....
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-01-2009, 01:31 PM   #21
Well i already raced 27t for 3 monce and it was b!00dy slow , then i tried 19 t , it was fast and good , but i wanted to race mod with some of the top driver so i went mod . lol
Old 01-24-2009, 09:11 AM   #22
Hi , im bringing this thread back beacaus i said that i will say how are my cells going on .
So, i have used each packs 3 times and i have cycled them 5 times and they still peak at 4357 mah , almost each charge .
all pack "peak cut " between 4325 -4386 mah .
Can i have my pack to cut with the capacity instead of peak cut ?
Thanks for any advice
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 01:14 AM
A123/LIFE Batteries advice needed. Govert Electric On-Road 28 03-02-2011 08:37 PM
Indoor Carpet Racing @ RC Performance in Madison Associated-08 Wisconsin & Illinois Racing 3426 11-25-2010 04:03 PM
R/C DIY stuff... Make it Yourself and save $$$ !!! kelfo Malaysian R/C Racers 408 01-05-2010 11:20 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
