Which mode on MuchMore Dicscharger?
I'm running 1/12 and therefore i still need Nimh batteries.
I'm using a MM CTX-D discharger and like to know which programme you guys are using.
Some battery matchers recommend deadshort, but i'm a bit scared to use that one.
Your thoughts?
Thx
BTW. topic is here because of most active users...
Your thoughts?
Thx
DO NOT what ever you do dead short your cells, you will very promtly kill them. Only discharge down to 0.9v per cell maximum..
Several use a combination of Pulse and Linear. At the track between runs "Linear" and at the end of the day (at home) Pulse and then add in about 1800 mah's over the week.
