Tire warmers amp draw? >
Old 10-20-2003, 01:43 PM
Cole Trickle's Avatar
Default Tire warmers amp draw?
Anybody know the amp draw from unregulated tirewarmers like Eagle?
Cole Trickle is offline
Old 10-20-2003, 02:24 PM
i got the eagle tyre warmers and i think they pull about 2-3 amps.
trf racer is offline
Old 10-20-2003, 02:29 PM
JimmyMac's Avatar
Mine were like 1.85 at 7.2v.
JimmyMac is offline
Old 10-20-2003, 02:32 PM
well i havent checked it i was guessing it would b 3-4 amps when fully up to temp.
Old 10-20-2003, 03:03 PM
Do these things really work? Won't the tires be at room temp already by the time you leave the pits then set your car at the grid? I'm thinking of getting one.
elnitro is offline
Old 10-20-2003, 03:05 PM
it depends on track temp
if its hot then no.
but if its cold then yes.
Old 10-20-2003, 04:25 PM
alfa's Avatar
but the tire may not feel hot but the insert should be, and this then will help heat the tire up faster during the race.
alfa is offline
Old 10-20-2003, 11:44 PM
I'll probably get tire warmers, so I could use some tires with a little harder compound in the cold - 0-10 degrees celsius track temp during the winther. The proper tires have bad economy...
I'm planning on using a power supply, instead of batteries.
Old 10-21-2003, 05:03 AM
sausage_link's Avatar
A little off topic here but would anyone know why my multimeter won't measure amps ???
I think I'm doing it right. You connect the meter in a series like you would connect a light bulb in.
sausage_link is offline
Old 10-21-2003, 05:33 AM
Sounds like it's connected correctly. Proper button selections (AC/DC etc.)? Have you checked the fuse?
