Old 12-31-2008, 04:29 AM   #16
TryHard's Avatar
Originally Posted by MattW View Post
I've had the sensor unit fail in a motor when using LRP speedo (a few times!!) and no damage to speedo or motor.
Same here.
| THard.co.uk | Xray | MuchMore |
Old 12-31-2008, 05:11 AM   #17
lochness42's Avatar
I had sensorwire pop off motor during run - pluged in and worked without problems and no damage on motor was registered.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 12-31-2008, 06:03 AM   #18
the problem probably occurred that the ESC wasn't seeing any feedback down the sensor wire, so carried on pouring power down the one phase of the motor, hence the burnout.
Brushless ESC's should auto-detect what sort of motor it is, brushed or brushless, and if in brushless mode, either kill the power if no feedback is received down the hal sensor harness, or revert to sensorless.
DA_cookie_monst is offline   Reply With Quote
Old 12-31-2008, 01:27 PM   #19
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
just a question... would it be possible just to change the sensor? I think Orion sells the sensor thingie separately...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-31-2008, 02:37 PM   #20
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by CarbonJoe View Post
Yikes! What happens if a sensor wire breaks during a run? Does it also switch to brushed mode? Doesn't sound like a good "feature" to me. The Tekin RS falls back to sensorless mode if no sensor is detected, which is a lot safer.
and thats another reason why its the best ESC today
SammyZ is offline   Reply With Quote
Old 12-31-2008, 09:52 PM   #21
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
TQ makes a super flexible sensor wire...order direct from them and I know Stormer stocks them as well.
-rocky b
flatspunout is offline   Reply With Quote
Team Orion Vortex Brushless motor Aku-Man Electric On-Road 719 05-27-2011 03:46 PM
