Old 12-28-2008, 03:00 PM   #1
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Default Brushless funny noise...and not ha ha funny
I posted this in the Speed Passion thread as well since the brushless system is SP, but I thought I would post it here as well hoping someone may be familiar with this issue:
Just fired up my new GT LPF and 13.5 for the first time, and under acceleration the motor makes a screeching sound...almost like a stripped gear squealing. Once it is running it is like butta. I checked the length of the motor screws and they are good, gear mesh is good. FDR is 5.78, ESC settings are:
Running Mode: 1
Drag Brake Force: 2
Low Voltage Cut-Off: 1
DRRS: 4
Brake Force: 2
Initial Brake Force: 1
Neutral Range: 1
AMTS: 1
Motor Type: 1
Over-Heat Protection: 1
Any ideas?
-rocky b
flatspunout is offline   Reply With Quote
Old 12-28-2008, 04:31 PM   #2
sportpak's Avatar
Trader Rating: 26 (100%+)
My 1/12th will do the when the diff is too loose. You said FDR, so I assume your running TC? Check the diff if your spur/pinion mesh is right. How does the spur itself look?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 12-28-2008, 04:43 PM   #3
It was the spur...it actually looks ok but I put on a brand new one and the noise stopped. All is well...
-rocky b
Old 12-28-2008, 04:43 PM   #4
Adam?'s Avatar
It sounds like the rotor magnet has come loose on the shaft, and is spinning under hard load. It's not a common problem, but certain one that's been seen before. Do you have another rotor you can try? Maybe SP will send you one?
Edit: Nevermind, glad to hear you figured it out.
Adam? is offline   Reply With Quote
