Picked up a Pro3 for free.  Curious as to what hop-up parts I should pick up. >
Old 10-19-2003, 12:19 PM
Default Picked up a Pro3 for free. Curious as to what hop-up parts I should pick up.
Here is what it comes with. What else would be good to pick up with it.
3 Deg C-Hubs Installed
HB Graphite Shock Towers (Front & Rear)
Shortened Shock Shafts (all 4)
Purple Aluminum Shock Caps
Purple Aluminum Spring Adjusters
Purple Aluminum Spur Gear Holder
Purple Aluminum Heatsink Motor Plate
DIY Torque Rod
Custom Graphite Upper Deck (not installed)
Custom Graphite Rear Brace (not installed)
Purple Aluminum Middle Shaft Mount
Purple Aluminum Center One-Way Pulley
Purple Aluminum CVD's (only on rear)
Kit Silver Springs Installed
Also Includes:
LOTS of Purple "dress up" items installed (washers, screws, nuts, etc)
Changed to hexhead screws in many locations
All stock parts, and extra part trees
AresPro3 is offline
Old 10-22-2003, 03:29 PM
Cole Trickle's Avatar
What do you plan to do, racing, bashing ?
Cole Trickle is offline
Old 10-22-2003, 09:43 PM
I plan on racing in a stock class of some sort.
AresPro3 is offline
Old 10-23-2003, 07:22 AM
Sounds great, is it your first car or do you already got a charger and springs etc.?
Old 10-23-2003, 09:36 AM
popsracer's Avatar
Default what hop-up parts I should pick up
AresPro3;
The Car sounds pretty well hopped-up already.
My suggestion is to install an Upper Deck.
The upper deck significantly reduces Chassis flex and the Car scrubbing off speed in the corners.
Next buy a full set of the 27mm Pro-linier Springs and you should be good to go.
popsracer is offline
Old 10-23-2003, 10:44 AM
It isn't my first car, so I have all the radio equipment etc. Just my first time with an on-road car. I used to bash a Losi XXT.
AresPro3 is offline
Old 10-23-2003, 10:52 AM
Okay, talk to the guys at the track, and get the proper tires. Ask the fast guys. The correct tire, is mandatory.
Next, get a good selection of springs and shock oil. It's also important to have the right gearing, so get some pinon and spur gears, if you dont got them already. The guys at the track, can suggest a good starting point for the gearing.
Old 10-23-2003, 10:59 AM
Here is a picture of the track I race on in my home town, they have a decent amount of tracks too. So I'll be sure to ask the shop owner and racers there what are the good combinations.
Home Town Track Home Page
AresPro3 is offline
