Any recommendation for stock 23 turns motor? >
Old 10-19-2003, 04:50 AM
Default Any recommendation for stock 23 turns motor?
Hi, I am searching for a good stock 23 turns motor for club race. Can anyone give me some suggestion? I heard that Yokomo is good, is it true? Thanks!
discus18 is offline
Old 10-19-2003, 05:06 AM
Stock motors are actually 27 turns, not 23.
Most people in my area are using the Trinity Monster stock motor. I've been using one for a while now and it seems to have a lot of top end power with a decent amount of low end punch.
Chad is offline
Old 10-19-2003, 05:16 AM
Johnny J's Avatar
He is talking about Jap Stock, they use 23t motors. There is a 23t motor thread on here that has HEAPS of info
Johnny J is offline
Old 10-20-2003, 03:39 AM
Trader Rating: 82 (100%+)
Default 23T thread
here you go:
http://www.rctech.net/forum/showthre...threadid=21233
hope this helps im using a tamiya Type S, as i cannot get other brands of 23T motors locally. the only changes i made were a set of stiffer springs (from a tamiya dynarun stock motor) and trinity silver brushes. i suggest getting rebuildable 23T motors, rather than the sealed endbell type
marvi is offline
Old 10-20-2003, 04:56 AM
audiaudi's Avatar
Default Xenon..
As long as you can get the Xenon products, you may try the Xenon Ao (the one with blue label) if you want a higher RPM instead of high torque, the Aka (red label) will be a good choice. You can PM me for further question.
audiaudi is offline
Old 10-20-2003, 04:57 AM
audiaudi's Avatar
Default Re: 23T thread
Originally posted by marvi
here you go:
Why don't you go online to search??
If you really want something different, PM me...
audiaudi is offline
Old 10-20-2003, 05:15 AM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Xenon..
Or if you want a Xenon motor that can lay the smack down..get the Momo... Power baby ..."POWER"
-Dave
JDM_DOHC_SiR is offline
Old 09-28-2004, 02:15 PM
asw7576's Avatar
In my Lhs people are talking yokomo and tamiya rz motor
asw7576 is offline
Old 09-29-2004, 12:39 AM
lazarus's Avatar
Default 23t
Take a look at the 23t motors from Kawada , go to www.kawadaracing.com or www.kawadamodel.co.jp for more info .Kawada's U.S distributor will have them in soon!!!
Kawada's have new endbell,dse connectors,r-coating for cooling and internel "fan blades " also for cooling.They will have the new "2004" vt-r model in .
lazarus is offline
Old 09-29-2004, 03:15 AM
pink pac man's Avatar
ive seen a tamiya stock [23] go and its heaps fast[red endbell] but i think the atlas 1 is the shizzle.......................well last time i herd anyway
pink pac man is offline
Old 09-29-2004, 03:56 AM
asw7576's Avatar
this kawada is cute , it has fan blades inside:
asw7576 is offline
Old 09-29-2004, 05:20 AM
The Kawada 23T`s are pretty good.. but I would only get there Torque version... VT-R.. this thing has "HUGE" ammounts of torque.. and a normal final drive is in the 5.4 range
-Dave
Old 09-29-2004, 05:27 AM
asw7576's Avatar
VT-R vs. VX-R ? are you sure u can beat X factor ??
asw7576 is offline
Old 09-29-2004, 05:31 AM
I have tested quite a few 23t motors over the past 2 years and the VT-R is a very good motor.. 95% of the people that use the Kawada 23T motors use this one
-Dave
Old 09-29-2004, 05:32 AM
lee82gx's Avatar
i wished they would use simpler code names though.
V,X,Y,T,R,Z all makes me go
lee82gx is offline
