Old 09-23-2009, 03:45 PM   #16
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by jiml View Post
32, 48, and 64 pitch gears refer to the number of teeth per inch, if you could lay it out straight.
The 0.4 and 0.6 module gears are based on a metric measurment (not sure exactly how it goes). So a 0.4 gear if you converted it would come out to something like 62.3 teeth per inch, which is why you can't use it with "standard" gears.
No! Pitch refers to the number of teeth the gear would have if it was 1-inch in diameter. A 1" diameter 32 pitch would have 32 teeth. A 1" diameter 48 pitch gear would have 48 teeth. etc...
Metric Module measures the height of running face of the gear tooth perpendicular to the center (also called the addendum). In an 0.4module gear, the running or contact face of the tooth is .4mm high...
94eg! is offline   Reply With Quote
Old 11-27-2011, 08:47 PM   #17
Send a message via AIM to Profoxcg
so a 0.6 module is a coarser "pitch" than then 0.4 is this correct?
If I am going to run two of three electric cars from different brands, my best bet would be to just use 64P gears so I can share across all cars correct?
Profoxcg is offline   Reply With Quote
Old 11-29-2011, 02:33 AM   #18
Yes & yes.
Sydewynder is offline   Reply With Quote
Old 11-29-2011, 09:02 AM   #19
thank you
TT-01 Forum mailboxck Electric On-Road 2526 12-09-2017 02:05 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
Hobbytown USA Overland Park Racing 2007 Core Creations Kansas/Missouri Racing 602 05-13-2008 09:11 AM
