Old 12-25-2008, 03:13 PM   #1
pmc
Default Xray new ECS front drive shafts
Hello
Someone has already tested the new XRAY ECS drive shafts on track??
what are your performance , durability??
Thanks in Advance
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 12-25-2008, 06:23 PM   #2
trickd122's Avatar
Originally Posted by pmc View Post
Hello
Thanks in Advance
Best regards:
Pedro Silva
It's definately NOT worth $50+ bucks a piece and not more durable than the current one availabe with the kit at $30+ a piece. Oh it doesnt make the car any faster or different. It like adding a pin stripe on a race car.
trickd122 is offline   Reply With Quote
Old 12-25-2008, 07:02 PM   #3
Skiddins's Avatar
They don't judder on full lock & full power with a spool unlike the standard driveshafts.
This should allow you to improve the cars balance through the corners by preventing that vibration.
But no, they are not worth as much as they are
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-25-2008, 07:06 PM   #4
If your going to give info at least try to be correct about it. The purpose of the new units is to almost completely eliminate the wheel chatter when using a spool. For the remedial that means when you have a spool in the car and are on throttle turn your wheels. You will see the inside wheel shake alot as it binds. With the new units it will almost eliminate that issue. Offer a more consistent feel and ultimately more speed throw the corner since the car isnt fighting itself. For and in depth description just goto TeamXray.com and it shows you exactly what their purpose is. Hope this helps...
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 12-26-2008, 01:08 PM   #5
pmc
Hello
thanks for all replys
I'm to buy these pieces so we asked opinions on the pieces because I do not want to spend the money and then not take advantage of cuts
I have visited the site of XRAY, but wanted to see how it behaves on the track, because there has been a different experience of how its performance with several different setups and ways to lead.
Best regards.
Pedro Silva
Old 12-26-2008, 11:36 PM   #6
RussB's Avatar
Send a message via MSN to RussB
the losi uses them in the front. they do make a difference with high steering angles and turning under power. the front end doesn't feel as bound up, and there's a lot less chatter.
the losi parts use shrink wrap to keep the pins in place and are a bit more delicate than a standard drive shaft.
the x-ray design looks a lot more substantial.
RussB is offline   Reply With Quote
Old 12-27-2008, 06:33 AM   #7
Skiddins's Avatar
Just remember to take them apart and put grease where needed when you first buy them.
I also used a Dremel grinder to put some flat spots on the pins as they move too easily for my liking, also means you don't have to tighten the grub screws very much, just make sure they are thread-locked.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 12-27-2008, 06:50 AM   #8
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Does anyone have them in stock online??
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 12-27-2008, 06:51 AM   #9
lochness42's Avatar
I managed to break pin in it during second race
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-09-2009, 01:53 AM   #10
Damon's Avatar
some pics of the new ECS drive shafts:
I installed these on my new T2'009 during assembly, with the old T2 wheel chatter was a pain...especially for Italian races, where we run with foam tires on asphalt tracks
in this particular case new ECS drive shafts are very useful, car feeling is really improved
Damon is offline   Reply With Quote
Old 01-09-2009, 08:36 AM   #11
Johnny Wishbone's Avatar
I don't know if this is correct on the track, but I have noticed when bench testing that I get less wheel chatter on full lock with the lightened outdrives compared to the older 360 outdrives.
Old 01-09-2009, 09:12 AM   #12
SlamMan's Avatar
$100 to outfit your car is a bit much still.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 01-09-2009, 03:53 PM   #13
Better much with foam tires on asphalt tracks?
higbo is offline   Reply With Quote
Old 01-09-2009, 05:21 PM   #14
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Must.
have.
for.
cyclone.
HB are you listening?
Syber Serulean is offline   Reply With Quote
Old 01-09-2009, 05:38 PM   #15
gonzo416's Avatar
Trader Rating: 39 (98%+)
I run XRAY and they are fenominal cars but if the ECS are such an improvement I can't seem to understand why XRAY didn't include them in the kit. You have to spend another $100 on top of over $400 for the kit to get it to handle better. That is why I will stay with my 08.
gonzo416 is offline   Reply With Quote
XRAY T2009 bola Electric On-Road 2679 07-06-2014 06:25 PM
XRAY T2R Pro c1 racin Electric On-Road 178 05-16-2012 09:23 PM
Xray T2 008 EU for sale pcar951 R/C Items: For Sale/Trade 8 03-16-2009 04:16 PM
