Micro Rs4 - Esc
Old 10-18-2003, 01:49 AM
Thunder racer's Avatar
Default Micro Rs4 - Esc
Hi people
i was just wondering what esc will go in to my Micro Rs4 because i brought and it dident come with a esc so i need one. I was think of gettting a GM-V4 will that be ok.
THANKS
any help would be great.
Thunder racer is offline
Old 10-18-2003, 03:51 AM
why not buy the novak spy. This one is cheap and it is made for the micro. Lrp also has one
sturla is offline
Old 10-18-2003, 07:13 AM
Like sturla said the spy is a good esc I run one in my stock micro setup...But I have found that i like the LRP Quntam sport better. The differences Ive noticed the spy doesent have the best brakes and not quite as much punch as the LRP...So if your gonna run anything above a stock setup i would say go with the LRP esp if you have ran 1/10 scale before...Also about the GM-V4 I dont know alot about it but some of the guys on the micro forums run them and love it.
micros4ever is offline
Old 10-18-2003, 08:01 AM
ChrisP's Avatar
There are currently specials to be had on the SX-9 if you like the GM ESC's...
Check around and you might be surprised...I just picked one up for $125 cdn....around the same price or only very slightly more than a Spy or an Orion Flash!
ChrisP is offline
Old 10-18-2003, 09:00 AM
Trader Rating: 81 (100%+)
is the micro your first car? i suggest that you get an esc that is also suitable for 1/10 scale just in case you want go into 1/10. the quantums are small enough for the micro yet you can use them for 1/10 racing
marvi is offline
Old 10-18-2003, 09:05 AM
oops, didnt see your sig there i should have said, if the micro was your first electric car
marvi is offline
Old 10-18-2003, 04:12 PM
Yer the micro is my first elecrit car ive got about ten fuel cars.
But im just buying the micro to have a bash around with in my new shed its got ploished concret and its 150meter by 150meters is that big or small for me the setup a lilte track with. Its just ready to pactise drive skills for when i go and race my MTX-3
THANKS for all your replys
I think i will go the GM-V4 becasue its so cheap but i will have a look at the LRP Quantum Reverse.
THANKS AGAIN
Old 10-19-2003, 09:20 AM
utieh's Avatar
i used to run a V4 in my micro, didn't have any problem with it`
just change the wires for thinner ones, give up tamiya plug for Dean's or mini PK and make directly sold it to the motor.
utieh is offline
