Old 12-24-2008, 01:35 PM   #1
Send a message via AIM to sszzxx
Default Gearing 17.5 brushless in TC5
How do you guys and how would i gear a 17.5 brushless novak gtb in a TC5. What is the final gear ratio im looking for etc....
sszzxx is offline   Reply With Quote
Old 12-24-2008, 01:44 PM   #2
mickrcarver's Avatar
Trader Rating: 99 (99%+)
have you tried www.gearchart.com then goto gear creator i think your final drive should be 3.5 fdr
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 12-24-2008, 01:47 PM   #3
Yah that chart just does the math for you if im using it right so someone around a 3.5fdr wont kill my motor ? I got a new brushless system and want to make sure i gear it right so i dont kill my motor yet can compete
Old 12-24-2008, 02:08 PM   #4
carbon madness's Avatar
Based on novak's GEARING RECOMMENDATIONS chart you should be around a 3.5 fdr. Then you can go from there on getting the right ratio, as with some esc/motor combo's you might need somthing that is higher (more acc.), and with others you might need a lower ratio.
If you want to be around 3.5, but would like it to be a little cooler you can start around 3.8, but heat really won't be a huge issue if you go by novaks chart.
for the chart
http://http://www.teamnovak.com/tech...r_gearing.html
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 12-24-2008, 02:12 PM   #5
AdrianM's Avatar
Hey, if you need them BMI racing is now selling 64p pinion gears from 45T to 60T.
www.bmiracing.com in the webstore.
Adrian Martinez
Old 12-25-2008, 12:14 PM   #6
losithrasher's Avatar
96spur and 53 pinion, perfect 3.5.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 12-25-2008, 12:26 PM   #7
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
For the tracks around here (80ft to 110ft straights), we gear from 4.0 to 4.6 fdr depending on track size / layout.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 12-25-2008, 01:36 PM   #8
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
is 3.56 ok or do i want it to be closer to 3.5 ?
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 12-25-2008, 02:13 PM   #9
that should be fine there but just temp often during practice
www.ovrccc.com
Old 12-25-2008, 02:27 PM   #10
if im running a novak 17.5 what should my temps be around?
W.P.A.C crawlers
The Raceway
Old 10-03-2011, 11:18 AM   #11
Trader Rating: 42 (100%+)
we have a med size track and I run a 75/39 48pitch with 17.5 no boost and 45' of motor timing and come off at around 127 degree after 6minutes of racing..
Team Radiopost-SMC Racing-R1wurks-Savox-AKA
XB2ce
BIGTRUX is offline   Reply With Quote
Old 10-03-2011, 11:58 AM   #12
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Im around 3.65. 54/98. With near max can timing. Might go back up to 3.8ish just to pull a little harder out of corners.
valk is offline   Reply With Quote
Old 10-03-2011, 12:59 PM   #13
For_the_win's Avatar
Im running 3.8
For_the_win is offline   Reply With Quote
Old 10-03-2011, 01:17 PM   #14
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I run 3.9, 17.5, blinky with 8* on the motor. I go up or down a couple teeth on my pinion depending on the longest straight. My temps range between 120 and 130. The more timing you add to the endbell of the motor, the more RPMs the motor is capable of turning, but at the cost of added heat because it is pulling more current. With my driving style, which isn't great, I prefer minimal timing on the motor, then I can use the low end torque in the infield.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 11-19-2013, 10:54 AM   #15
Schs2013's Avatar
Hi guys, I have been running my TC5 for VTA lately just wondering if the current gearing i have will work with a 17.5 44/96 my FDR 4.36
VBC Lightning 10LM 21.5, WCICS spec M05v2, VBC D07 21.5 USGT
Schs2013 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13256 12-15-2017 05:13 PM
Team Orion Joe Pillars Team and Company Discussions 486 05-06-2017 03:02 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
