Old 12-21-2008, 08:24 PM   #1
nexxus's Avatar
Trader Rating: 302 (100%+)
Default Silly Question re Tyre Inserts
Ok, not too cluey with Tyre inserts so a couple of Q's
Whats the difference between Sorex A, B and C inserts?
Am I going to find much difference between Sorex A Medium inserts (which I was told I should use) and Much More A Medium-Firm inserts (which is what I have in my pit box)
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 12-21-2008, 08:31 PM   #2
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
The letters on sorex inserts refer to thickness.
The medium or firm refers to how hard the insert is.
Thicker inserts fill the tyre more, dont allow as much sidewall flex and keep the tyre warmer (no room for air circulation).
Thin inserts allow for a wider contact patch on the tyre, more sidewall flex and let the tyre run cooler.
Hard inserts are good for smooth, high speed tracks.
Medium inserts are good for bumpy, lower grip tracks (medium allows for more contact patch and flex also).
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 12-21-2008, 08:46 PM   #3
nexxus's Avatar
Ok well I was recommended A mediums for the track we both race on, (Sorex A Mediums) so will A Medium-Firm be noticably different.
What do you recommend for Bayswater?
