Old 12-22-2008, 10:09 PM   #31
bkspeedo's Avatar
I'm of the theory that all these motors are pretty much created equal because of ROAR rules. What I think makes the difference and not everyone is aware of this, that all BL motors can have their timing adjusted. For those thinking Novak motors are slow adjust the timing by losing the three screws on the back and turn the plastic ring counter clockwise as far as you can. You will be amazed at how much this changes the speed of the motor.
13.5 to 21.5 motors should all be run with maxim timing. When you buy a motor you don't know where the factor as them set except for Orion, some LRP, and some Speedpassion, and now the DUO's with timing marks. From my experience most are set to the middle timing range which is about 10-15deg.
The one area that seems to be different between the BL motor vendors is the power band. One vendor might have more torque at low rpm and another at high rpm. So for a large track Motor A might work well and for a small track Motor B may work better. It's hard to say which is better unless you can test each motor yourself. Even there you could use 5 motors from the same vendor and probably notice a difference as each motor has slightly different characteristics due to coil winding and how symmetrical the rotor is magnetized.
What would be cool is if someone with a motor dynamometer could test several motors from each vendor and post results.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-28-2008, 01:12 AM   #32
CJ RC's Avatar
http://www.amainhobbies.com/product_...ducts_id/33177
anyone try?
______________________________________________________
| ABSOLUTE HOBBYZ | AKA | HB RACING | OS | KO PROPO |
CJ RC is offline   Reply With Quote
Old 01-03-2009, 07:49 AM   #33
sickpuppy1's Avatar
Trader Rating: 27 (100%+)
I know my Fantom doesnt work for poop with my Sidewinder. Timing set to 0, wondering if moving it to 10 or 20 degrees would help?
sickpuppy1 is offline   Reply With Quote
Old 01-03-2009, 09:03 AM   #34
fleetmaster's Avatar
Trader Rating: 16 (100%+)
only one way to find out i guess.i'm new to b/l motors,very interested to try this on my motor too.
can you adjust while the motor is running??
fleetmaster is offline   Reply With Quote
Old 01-03-2009, 11:29 AM   #35
OvalDude99's Avatar
Any one tried Putnam or Team Scream motors? I have herd good things about the Putnam but nothing on Team Scream.
OvalDude99 is offline   Reply With Quote
Old 01-03-2009, 07:15 PM   #36
Trader Rating: 35 (100%+)
Default motors
both are just trinity based duos, which are good motors. i think putnam may dyno motors, but overall all duos are good.
nazman01 is offline   Reply With Quote
Old 01-12-2009, 09:36 AM   #37
Trader Rating: 20 (100%+)
Default Trinity Pulse
One guy at Tacoma Raceway bought one of those Trinity Pulse 8.5 and he likes it so far (He said, first batch of the Pulse had some problems). I'd like to see a comparison between Novak SS 17.5 vs Hacker 17.5 vs Trinity Pulse 17.5.
javacrazy is offline   Reply With Quote
Old 01-12-2009, 03:46 PM   #38
OvalDude99's Avatar
Todd does some work to them, but I think $100 for a motor is a bit much.($80 without the ceramic bearings)
Old 01-12-2009, 05:18 PM   #39
davepull's Avatar
all TP does is if requested he installs ceramic bearings
davepull is offline   Reply With Quote
Old 01-12-2009, 06:39 PM   #40
OvalDude99's Avatar
According to his post at DirtOavl.com he does dyno tuning and something with the rotor.
From his post:
"Our Blueprinted Line Includes:
-Dyno Results Printout
-Rotor Strength (Gauss Measurement)
Ceramic Bearing Upgrade / Installation is also available for $20."
Still seems like a lot of cash for a motor but the guys I have talked to say it's worth it.
Old 01-12-2009, 08:54 PM   #41
Has anyone tried the 2nd gen. LRP 17.5?
M3dreamin2008 is offline   Reply With Quote
Old 01-12-2009, 09:13 PM   #42
Trader Rating: 8 (90%+)
I ran a Pulse, the new one, this past weekend. It seemed very flat no matter where it was geared or timing was set. I was 2tenths off, I put my hacker back in, and ran 3 tenths faster lap and 2 tenths faster avg lap.
Johnny Carey is offline   Reply With Quote
Old 01-13-2009, 11:01 AM   #43
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Johnny so the version 2 pulse motor is no better than the first version ?
wallstreet is offline   Reply With Quote
Old 01-13-2009, 11:43 AM   #44
I only ran the ver2. It ran smooth for 4 runs, it just had no pull. I tried timing from 0-15, and couldnt get the torque out of it.
Old 01-13-2009, 11:51 AM   #45
wallstreet's Avatar
Thats not good to here
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 10:16 PM
which brushless system should i use? smiley777 Electric Off-Road 22 01-28-2009 07:28 PM
best s**t box :D open to opinions :D xxblackheartxx2 Electric On-Road 36 01-11-2009 04:45 AM
new to drifting emt59602 Rookie Zone 8 10-18-2008 12:07 AM
returning to 2wd..technology questions (brushless/lipo) BlazinB4 Electric Off-Road 6 10-01-2008 10:14 AM
ROAR B/L motor Rules debate thread C_O_jones Electric On-Road 1080 01-21-2008 08:00 PM
