silver solder
Old 10-17-2003, 01:26 AM
Default silver solder
hey
does any one know if silver solder (stick solder)
would be better then 60/40 for soldering batteries together.
thanks
acid_rain182 is offline
Old 10-17-2003, 03:05 AM
sosidge's Avatar
The melting point of silver solder is too high, and the extra heat you need could damage the cells.
sosidge is offline
Old 10-17-2003, 09:19 AM
popsracer's Avatar
Default Using Silver Solder
acid_rain182;
Exactly, and the RE-melting point of Silver Solder is even higher, when you resolder. I settled on 60/40 for this very reason.
popsracer is offline
Old 10-17-2003, 11:35 AM
Super Moderator
Grizzbob's Avatar
Right, & keep in mind that there should be VERY little solder between the surfaces you're trying to connect, so using silver solder will not improve conductivity or reduce resistance by a noticable amount(as long as you soldered everything properly), the key is the two materials you're connecting. That's why you shouldn't use any more solder than is absolutely neccessary.....
Grizzbob is offline
Old 10-19-2003, 05:38 AM
Kester '44'. 60/40 rosin core solder, smallish size. If it's good enough for almost every electronic application out there, I think its good enough for my batteries... I think a good, clean solder job is more important than trying to use silver solder to get more performance.
spyderx is offline
Old 10-19-2003, 08:12 AM
Matt Howard's Avatar
I've only used or seen silver solder used where the temps of the application would melt regular solder right off (jet engine). You would be frying your battery trying to solder with the stuff or melting your endbell trying to use it there.
Matt Howard is offline
Old 10-19-2003, 11:59 PM
Isn't Dean's and Acer's Silver solder??
Sydewynder is offline
Old 10-20-2003, 06:13 AM
it's got some silver in it but we're talking about different stuff
Old 10-20-2003, 06:47 PM
Super Steve's Avatar
so deans' solder is ok, rihgt?
Super Steve is offline
Old 10-20-2003, 07:22 PM
Registered User
Calvin Ng's Avatar
how bout the stuff with rosin inside of it?
Calvin Ng is offline
Old 10-20-2003, 07:31 PM
popsracer's Avatar
Default Soldering
Guys;
Just use regular Rosen Core Electrical Solder (60/40) to avoid any problems.
If you're concerned about the packs coming apart in a crash, use some CA or Shoe Goo to hold the batteries together. If you really ever need to disassemble the packs, they're probably at the end of their usable lifetime anyways.
