Old 12-18-2008, 01:35 PM   #1
Akhor's Avatar
Default Drive Terrain Belt Tension
What is the best way to tell if your belt tension (on a x-ray 008) is set correctly?
I've been trying to find articles, but so far... Nothing
Akhor is offline   Reply With Quote
Old 12-18-2008, 02:17 PM   #2
Regional Moderator
Jim Herrmann's Avatar
Set - Check - Adjust.
A safe bet is to find the tension that begins to drag down the freespin of the system (on the bench) and call that 'appropriate'. When you apply a load the belt stretches just a little bit, so that extra drag goes away durring operation.
Also, looser belts not only skip, and/or roll over, but they subject themselves to vibration and getting torn up on nearby items.
James Herrmann
Jim Herrmann, ex-Professional (turned Life Coach)
Jim Herrmann is offline   Reply With Quote
Old 12-18-2008, 03:57 PM   #3
Skiddins's Avatar
If you 'ping' the main belt with your finger and it vibrates like a rubber band it's too tight.
You can get vibrations that can occur at certain frequencies where the belt will vibrate (like a rubber band) causing drag in the drivetrain.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-18-2008, 04:34 PM   #4
Impulse_racer's Avatar
Stock - as loose as possible without skipping
19T - a little tighter that Stock without skipping
Mod - follow the suggestion of the guys above
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
R/C Stuff Wanted Kenneth Tan Singapore R/C Racers 10018 09-09-2009 08:32 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
belt vs shaft Quietroit Nitro On-Road 112 07-14-2004 02:40 PM
