question for the mini z guys >
Old 10-15-2003, 10:59 PM
stoopidbstrd's Avatar
Default question for the mini z guys
what is the significance of wider wheels?
and
what is the significance of not using stablizers in the front?
much thanks
stoopidbstrd is offline
Old 10-16-2003, 12:51 AM
S-T-R-l-K-E-R's Avatar
wider wheels would give a better contact patch. this would give the car more traction(for the rear) and more steering power(for the front).
front stabs act like a swaybar.
i always use wide wheels for the rear and medium sized whells for the front.
try running your MZ with out any front stabs. and get a roll shock for the rear to give you car a more planted/ stable feel.
S-T-R-l-K-E-R is offline
Old 10-16-2003, 02:59 PM
thanks a lot
there's one more thing i just thought of.
have you ever heard of a brand named PN racing?
they made a motor that was faster than the xspeed called the Speedy motor. it requires no turbo esc upgrade, but it sometimes burns the board on the MZ. i was wondering if you have ever heard of something like that and if it can be prevented when using the motor.
much thanks
Old 10-16-2003, 06:57 PM
i personally have witnessed a board fried by that particullar motor. it didnt fry the board at once but after many runs my friends Z just stopped and it had a distinct odor. i really recommend installing a turbo. this will protect your Z board and give your car hella torque!
more torque + more topspeed = moer FUN
Old 10-16-2003, 07:00 PM
so true
much thanks
Old 10-16-2003, 07:19 PM
Fire's Avatar
all PN motors except the speedy is designed for either turbo or fet, stock pcb can't stand the current draw
Fire is offline
Old 10-16-2003, 10:44 PM
alrighty
does square make wide wheels or are they all standard size?
all i can find are standards sizes. do they have a website?
Old 10-16-2003, 11:07 PM
thedonut's Avatar
www.rc-square.com
thedonut is offline
Old 10-17-2003, 11:28 PM
i cant read any of that but thanks.
ill just go to babblefish and translate it.
Old 10-18-2003, 01:09 AM
Fire's Avatar
yes square makes both normal and wide rims set
they recently released the utra wide rims set for Enzo
Fire is offline
