Old 12-17-2008, 05:31 PM   #1
chappi's Avatar
Trader Rating: 17 (95%+)
Default Li-Fe Battery on Futaba 4PK , Better!?
Just wondering is there any Futaba 4PK user has try the battery below
I am wondering what is the benefit, compare with the Ni-MH 1700mah battery that comes with the 4PK ?
Is it better then the battery comes with the 4PK package ?
chappi is offline   Reply With Quote
Old 12-17-2008, 05:42 PM   #2
RCSteve93's Avatar
It definitely has more voltage. More wattage also...
6.6V * 1500mAh = 9900 watts
4.2V * 1700mAh = 7140 watts
I hope I did my math right.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 12-17-2008, 06:03 PM   #3
chappi's Avatar
Is that mean that it can last longer between each charge? ( sorry I am not very good at the electrical stuff )
Also, if the voltage is higher, is that also means that it will be easier to burn the electronic component inside the 4pk !?
Old 12-17-2008, 07:37 PM   #4
RCSteve93's Avatar
In theory, yes (That is if my math is right). It should last longer. It will also be much safer due to the chemistry.
Normally there is a high tolerance on electronics. It should work fine with anything between 3.6 - 7.2 volts.
rm -rf /windows
