LRP Competition Charger Problem? >
Old 10-15-2003, 05:57 PM
Unhappy LRP Competition Charger Problem?
Hi all,
I recently acquired a LRP Pulsar Competition Charger and experiencing what I believe to be problems with it. The problem is that it won't stop charging even though it displays the mah greater than the what the battery is rated at (for example it would display 3200mah output for a battery rated at 2300 mah at it would be still charging)
I am using Linear mode of charging with a 12V battery 17ah & Delta peak is set 30.
I am charging, non-empty:
- 1 cell 1.2v C Cell Battery rated 2300mah NiMH (set at 0.3a charging)
- 6 cell GP 3300 mah NiMH (set at 0.5a charging)
- 5 cell 730mah NiMH receiver pack. (set at 0.1a charging)
Am I doing something wrong?
Thanks for your input guys
Sami
ttektek is offline
Old 10-15-2003, 07:13 PM
popsracer's Avatar
Default LRP Competition Charger Problem?
ttektek;
The Charger detects the Peak voltage of a pack to determine when a pack is fully charged.
So no matter what the rated mAh of a pack, the Charger will not stop until the voltage is at maximum (peak).
popsracer is offline
Old 10-16-2003, 05:08 AM
Cole Trickle's Avatar
Default Re: LRP Competition Charger Problem?
Your charging rates are really low - 0,5 amps on a six cell 3300 ?
At such low amps, my capacity meter even wont work - it's another charger though. At such low rates, the delta peak become very small, so it might be a problem to even detect it.
0,5 amps on a six cell GP3300 - dont you mean 5,0 amps?
Cole Trickle is offline
Old 10-16-2003, 06:07 AM
Thanks for replies,
Cole, I have always been told to charge at 10% of the amp rating of a battery to keep working as long as possible.
Am I charging at a too low amps? Is the a general rule with charging with these professional chargers? Is there a info sheet? Or can you tell what settings i should have for the 3 types of batteries I am charging.
Sami
ttektek is offline
Old 10-16-2003, 06:45 AM
berger's Avatar
There was a data sheet provided with mine, and it says for sanyo rc2400s to charge at 6.0A with a delta peak of 80Mv. And for 3300 Gp 5.0A with a 10Mv delta peak. Charging at that speed will take hours to charge!
berger is offline
Old 10-16-2003, 11:20 AM
The higher the charge rate is, the better the charger should be.
So in many consumer products (shavers, toothbrushes etc.), the charge rate is quite low, thus they can produce the charger cheaper !
But... you got an high end charger And your batteries are made for these high rates
So you can safely charge your batteries at much higher rates ( if your power supply supports it )
This will both save a lot of time AND makes your car way faster. The higher amps, the more punch you'll get out of your car (at least to some extend).
I'll say: Charge your GP's at at least 5 amps. On this site, Promatch (who match batteries for living) have som recommendations. Promatch
Your TX pack: Divide the capacity by 2, so 3-400 mAmps. If you're in a hurry, go to 0,73 amps.
The single cell: It'll depend on brand and purpose, but with the same rules as for the TX pack, you'll be on the safe side.
Old 10-16-2003, 07:30 PM
lee82gx's Avatar
u wont peak as usual charging at 0.3A's
if this is what u want to hear,it is OK to reach 3200 for 2300 at 0.3A's
at such low charge rates,ur cells are mostly turning the current into heat,hence the longer time it takes to fully charge it.
lee82gx is offline
