Team Magic E4RS 2009 Edition >
Old 12-19-2008, 05:47 AM
  #16
nocif13's Avatar
FOR THE PARS =>RCMANUFACTORY
TM europe is closed because he have not exclusiv contract in europe
best regards
olivier gremillet
nocif13 is offline
Old 12-19-2008, 08:28 AM
  #17
CanyonCarverR1's Avatar
Is that a gear diff in the rear? I hope so!
CanyonCarverR1 is offline
Old 12-19-2008, 08:34 AM
  #18
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
its a ball diff
Marcos.J is offline
Old 12-19-2008, 10:07 AM
  #19
Trader Rating: 26 (100%+)
when will this be available
eddie10 is offline
Old 12-19-2008, 10:51 AM
  #20
Eddie M's Avatar
It is already available. I ordered one from mushroom. well see if I receive it before Christmas...
Eddie M is offline
Old 12-20-2008, 11:29 AM
  #21
Tomradio's Avatar
Trader Rating: 25 (100%+)
I want one!
Tomradio is offline
Old 12-20-2008, 05:54 PM
  #22
does anyone know if the big 5000 mah lipos will fit.
eddie10 is offline
Old 12-20-2008, 06:01 PM
  #23
mild seven's Avatar
Trader Rating: 63 (100%+)
looks good. might have to get one to try out. One thing that put me off on the old E4 was the double steering crank.
mild seven is offline
Old 12-23-2008, 09:49 AM
  #24
blee's Avatar
Thumbs up
Coming Soon!
blee is offline
Old 12-23-2008, 09:59 AM
  #25
Ill have my e4rs 2009 tommoro. All the hong kong shops have it in stock. Rc mushroom has it for 389.00 usd
eddie10 is offline
Old 03-02-2009, 11:40 PM
  #26
Trader Rating: 11 (88%+)
Default Cheaper version
The 09 version accually has some cheaper parts on it as a cost saving measure. You are better off buying the E4RS or the E4FS for 349.00 at wolf hobbies.
hooj74 is offline
Old 03-05-2009, 01:22 PM
  #27
Eddie M's Avatar
Which parts are the cheap version in the 09 then the standard E4RS?
Eddie M is offline
Old 03-05-2009, 05:51 PM
  #28
cheehtae's Avatar
Trader Rating: 15 (100%+)
so can you convert your 08 to an 09?
cheehtae is offline
Old 03-05-2009, 09:39 PM
  #29
katfish317's Avatar
If you want to save money on parts you can use the E4J parts as a substitution if needed. I am using axles and hubs on mine and they are great nothing too it, just have too order the hubs, and save like twenty dollars on axles.
katfish317 is offline
Old 03-31-2009, 11:26 PM
  #30
blee's Avatar
Thumbs up
E4 Alum. 7075 Adjustable Single Bell Crank Steering Set
Item No : K2121
Spec : K2121
blee is offline
