Old 02-26-2009, 03:18 PM   #286
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
Originally Posted by javacrazy View Post
Does mAh has an effect on punchyness of the battery?
Say, is SMC 3200 mAh/40C punchier than Trinity 5200 mAh/35C?
I own both and on a Novak GTB/Novak 17.5, I don't feel there is a difference between the two except the weight.
As long as they can handle the current draw, and keep the voltage similar, you won't really notice a difference between the two.
A higher C rating also means that the battery can keep its voltage up better under load.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 02-26-2009, 03:28 PM   #287
Send a message via ICQ to Jan Larsen
Originally Posted by Danny/SMC View Post
The mold is finally done for the new cases and we should have the case in 10 days or so. This means the 4700/40C+ pack should be in by the 3rd week of March. The height will be 22mm so this will be a good pack for those who have low topdecks.
Will they have the cell slot bumps? Hopefully not. If yes, can they be dremeled down without destroying the case?
Jan Larsen is offline   Reply With Quote
Old 02-26-2009, 03:50 PM   #288
Trader Rating: 20 (100%+)
Thumbs up
Thanks for the explanation.
That explains, why I felt a huge difference between Reedy 5000 mAh/20C and 5200 mAh/35C. My GTB was drawing more current than my 20C pack can handle.
"Slow is fast." I drove slow but why am I still slow?
javacrazy is offline   Reply With Quote
Old 02-26-2009, 04:06 PM   #289
drperry's Avatar
My GTB is thirsty on power, as well
Even only with a 13.5
Old 02-27-2009, 12:19 AM   #290
Does the 24.5 mm for the 40C 5200 mAH include the cell slot bumps or is the battery flat on the bottom?
My T2008 has just under 23 mm clearance under the top deck, and I don't want to fiddle with shims to raise the top deck.
If the 40C 5200 mAH will not fit in the T2008, when will the 22 mm high 40C 4700 mAH battery be available. Thanks.
Jongo is offline   Reply With Quote
Old 02-27-2009, 01:46 AM   #291
lbckevin's Avatar
Trader Rating: 91 (99%+)
battery is flat on the bottom...no bumps
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-27-2009, 01:49 AM   #292
ngo8's Avatar
Send a message via ICQ to ngo8
hey bud i just got one of these packs and its a perfect fit on my 009 but i am using the included lipo kit i also glued the pack on a ppd lipo plate and it fits right on the money you shouldnt have any problems with it .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 02-27-2009, 07:12 PM   #293
Hello all,
Just wondering what numbers people are seeing on their new 5200 packs.
Cheerz.
Obsidian is offline   Reply With Quote
Old 02-27-2009, 08:28 PM   #294
Verndog's Avatar
Trader Rating: 16 (100%+)
When did I miss this? That will prove to be a smart move IMO. Great news....and glad I only bought 1 3800
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-27-2009, 10:16 PM   #295
Davidka's Avatar
Trader Rating: 77 (100%+)
Say, is Thunderpower 3200 mAh/40C punchier than Trinity 5200 mAh/35C?
Between those two batteries there should not be a noticeable difference as they are both pretty top quality. There is a math reminder in this though, "C" rating is directly related to capacity, ie. a 3800mah/30C (able to handle 114 amps) battery can't manage the same amp draw as a 5200mah/30C (able to handle 156amps) because "C" rating is a multiple of the pack's capacity. At a given "C" rating, bigger is always better and the less taxed a pack is the better. They will perform better and last longer.
Old 03-05-2009, 10:33 PM   #296
mojoman's Avatar
Bump.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 03-06-2009, 03:59 PM   #297
Company Representative
Danny/SMC's Avatar
Should have pictures next week of the new EFRA cases. Test shot being done this week and if all is good case will be molded by next week.
Danny/SMC is offline   Reply With Quote
Old 03-07-2009, 12:28 AM   #298
mojoman's Avatar
Sweet!
Casey Castleman
Old 03-10-2009, 08:08 AM   #299
Will these 4700 EFRA packs be imported to the UK by CML? They don't seem to carry any of your lipo's at the moment.
ads0021 is offline   Reply With Quote
Old 03-10-2009, 01:13 PM   #300
Danny/SMC's Avatar
Yes CML will carry the 4700/40C+ and the 5000/28C+ EFRA packs. The 4700 will be released first.
