Old 01-15-2009, 07:48 AM   #181
mo
mo's Avatar
Hey Danny. I've been e-mailing you the last couple weeks. Have you gotten them?
Jason Moberly
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-15-2009, 08:43 AM   #182
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
where will it stop, u could say people will gravitate more to mod where it doesnt matter as much. but motors/batts are not gettin any slower, and tracks are not gettin any bigger. hmm
R
UltegraSTI is offline   Reply With Quote
Old 01-15-2009, 08:52 AM   #183
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Danny/SMC View Post
The EFRA pack will replace the 4000/28C pack. So the thinnest pack we will have is 23.5mm
So the 23.5mm measurement is to the bottom of the humps? Since most humps serve little to no security in locking to chassis, people will just grind those off and use a baseplate for sedan. So is it close to 21mm excluding the humps?
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 01-15-2009, 11:46 AM   #184
Company Representative
Danny/SMC's Avatar
Jason Moberly
I get so many emails that when I know somebody I take time to respond and then it gets shuffled down the list. I will dig up your email and reply in today.
Danny/SMC is offline   Reply With Quote
Old 01-15-2009, 11:48 AM   #185
Danny/SMC's Avatar
No 23.5 is without the bumps as EFRA has seperated the bumps from the actual cell compartment. So it's 23.5 and 25.00 with bumps.
Old 01-15-2009, 04:39 PM   #186
DiFabio42's Avatar
Wow, Sweeet. I will want to buy 2 of those 25c 8600mah Packs for my E-Revo! This will be a big hit! So the estimated price will be about $125?
DiFabio42 is offline   Reply With Quote
Old 01-16-2009, 05:47 PM   #187
Danny/SMC's Avatar
Yes the MAP price will be 125.00
We expect to have these by the end of February.
Old 01-16-2009, 05:48 PM   #188
Danny/SMC's Avatar
We finally had a chance to cycle 5 random production 5200/40C+ packs. Results are what we expected based from the info our supplier gave us.
Packs were charged at 10 amps on the Hyperion Duo Balance charger and discharged at 35 amps on the GFX. Voltage sensing leads were attached on the 12 gauge wire where the Deans connector is soldered to the packs power leads. Room temp was 73 degrees and the packs were cycled 2 times as when they came in they were cool/cold. The numbers are from the second cycle which was started one hour or so after the first cycle was done.
#1 557 (5415mAh) - 7.46V - 5.2 IR
#2 549 (5337) - 7.44 - 5.4
#3 539 (5240) - 7.44 - 5.2
#4 536 (5211) - 7.45 - 5.5
#5 541 (5259) - 7.45 - 5.2
Old 01-17-2009, 05:24 AM   #189
kschu's Avatar
Send a message via MSN to kschu
danny, do u hv any lipo tat can fit in Serpent S400 ?
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-17-2009, 10:14 AM   #190
Danny/SMC's Avatar
I'm not familiar with that car. How much length do you have before you hit the bulkheads ?
Old 01-17-2009, 10:15 AM   #191
Danny/SMC's Avatar
We have been talking about some packs for the E-Revo so I created a section on the SMC area of this site for these new packs.
http://www.rctech.net/forum/smc-supe...ipo-packs.html
Old 01-18-2009, 03:32 AM   #192
kschu's Avatar
Hi danny, this is the maximum size that can fit into my car.
Length137.5mm)x Width45mm)x Height23mm)
thanks
Old 01-18-2009, 11:10 AM   #193
Danny/SMC's Avatar
Wow that isn't allot of room for a hardcase Lipo pack. Most case are 46.5 to 47mm wide and the length is 138.5 to 139.
Old 01-18-2009, 07:25 PM   #194
kschu's Avatar
i'm using IP 3800mah now...it's fit well into my car but i would like to try SMC lipo...
Old 01-20-2009, 10:03 PM   #195
Danny/SMC's Avatar
Here is some info some might like to know about our Lipos. As I have said before these are made exclusively for us and we feel there the best Lipos made to date. The R&D of our supplier is extremely strong and improvements are being made regularly. One of they key features of our packs besides low IR and good average voltage is cycle life. The 3D helicopter fliers have noticed that our Lipos have much better cycle life than any other packs they have flown.
Here is a cycle life test on our new 40C+ cells that shows how a cell can be tested to see how it holds up to cycling. This tests consist of 100 straight cycles. This is harsher than doing 100 cycles with rest but it's still showing how a cell will drop over each cycle.
Here is how the test is setup:
Step 1. Charge the cell at 1C at CC mode.
Step 2. Charge the cell at CV mode
Step 3. Rest for 5 minutes
Step 4. Discharge the cell at 50 amps
Step 5. Rest for 8 minutes 20 seconds
Repeat the cycle for 100 times.
The first mAh reading is charge and the second is discharge.
Our supplier tells me that the acceptable standard is that a cell/pack must stay at 70% of it's capacity over 100 cycles. Were very pleased to see that our cells are at 91% which is a very high standard. Test from other brands of so called high cycle life cells have been at 75% .
SMC 40C+  C-Max 7.4V Hardcase Lipos-100-cycles-50a-1-.jpg   SMC 40C+  C-Max 7.4V Hardcase Lipos-100-cycles-50a-2-.jpg   SMC 40C+  C-Max 7.4V Hardcase Lipos-100-cycles-50a-3-.jpg
