Old 12-13-2008, 10:50 PM   #1
iLL-Mitch's Avatar
Default Best choice ESC/Motor Combo for 13.5 touring???
Here are the three i was looking at... Please give my your input... Thnx
TEKTT2152 Tekin RS Sensored Brushless ESC/Motor Combo 13.5T
ASCLRP80582 LRP A.I. Brushless Reverse Digital ESC & Eraser Brushless Motor Combo (13.5T)
NOV3013 Novak GTB SS13.5 Pro Brushless System (ESC + Motor)
iLL-Mitch is offline   Reply With Quote
Old 12-13-2008, 11:08 PM   #2
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
The Tekin RS setup is the best in that list.
ChristopherKee is offline   Reply With Quote
Old 12-13-2008, 11:29 PM   #3
I would recommend you to take a look at speedpassion. They are better value for the money
vhmlaw is offline   Reply With Quote
Old 12-14-2008, 12:20 AM   #4
Hoggy's Avatar
Trader Rating: 26 (100%+)
either speed passion or team wave
Hoggy is offline   Reply With Quote
Old 12-14-2008, 03:36 AM   #5
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
LRP TC Spec + Orion Vortex 2008 Stock
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-14-2008, 08:58 AM   #6
AdrianM's Avatar
I second the Speed Passion suggestion. Thier speedo is the most advanced and easiest to use on the market right now and their 13.5 motor is one of the fastest.
Adrian Martinez
Old 12-14-2008, 10:35 AM   #7
imjonah's Avatar
Default Tech Question
Tech question for you Adrian.
Technically shouldn't all 13.5 Brushless motors be identical "speed" or torque at a given RPM. The designation '13.5' is nominal isn't it? There not in fact 13.5 turns of wire in it? Isn't the 13.5 the result of using some agreed upon formula for converting KV?
A related question I assumed the two rationales for adopting Brushless were
1. greatly reduced maintenance time and costs
2. Level playing field, everyone in any given class 13.5 17.5 getting the same exact power.
also since the cost of manufacturing different brushless "winds" 13.5, 17.5 is virtually identical couldn't ESC be produced that could be programmed to match each spec, in other words one motor one ESC, click a switch to change to a different spec?
imjonah is offline   Reply With Quote
Old 12-14-2008, 01:20 PM   #8
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
True that 13.5 is a fixxed entity. But the fact is all depending on timing , rotors and yes .. the windings. But if you have looked up any ratings on motors some claim more rpm's but less torque or what I like to refer to is the watts output and rpm. The higher the watt, the more power you have . Litterally watts is power! Fact of the matter is every one is fast. All you need to do is find that sweet spot to run the motor in. Track.. grip. temp. all that makes so much difference with a brushless I feel there is a wide margin or ratios that you can use but there will always be that one perfect gear for every different motor. Once you have determined that , then you can concider which one is faster ...
John St.Amant is offline   Reply With Quote
Old 12-14-2008, 01:25 PM   #9
RC MARKET's Avatar
this moment
Tekin RS Pro or Orion Vortex ESC
& Orion Vortex 2008 Motor
RC MARKET is offline   Reply With Quote
Old 12-14-2008, 11:07 PM   #10
AdrianM's Avatar
Well, BL motors are a lot closer speed wise than brushed motors were. Mainly because the rules for BL are A LOT tighter than for brushed motors. That said there is some leeway in the rules. There has to be so motor companies can innovate and make improvments over time. A very knowledgeable BL motor guru I know told me there is ~5% spread between the best and worst BL motors in any given wind. This is due to the steel used in the stator laminations, the quality of the rotor magnet, quality of the copper in the windings, how well wound the stator is...etc. There are a lot of small variables that can add up to make one motor better then another.
OK..the questions:
There are 13.5 turns or wire on each pole of the stator in our motors. There are front and rear terminated motors that dont have the extra .5 turn. This is why there are some mods that are 4.0 and 3.0 turns.
LRP's first Sphere has a motor limiting feature. It sort of worked but it was not very smooth. Speed control limiting of motor power is certainly possible. The problem is it is impossible to tech and even harder to prevent guys from cheating. So...we run diffrent motors.
Adrian Martinez
Old 12-14-2008, 11:31 PM   #11
Im still waiting for my Orion speedo.....
Old 12-15-2008, 01:52 AM   #12
I'm still stressing the Tekin RS. It's the smallest and has the most flashy lights and sounds out of all the ESCs. You will not be disappointed.
Speed Passions low profile is my second choice. They take a liken and keep on ticken
Old 12-15-2008, 05:00 AM   #13
Joel Lagace's Avatar
i switched form GTB to a Losi combo and love it. Excellent programmability
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-15-2008, 07:02 AM   #14
If low price is a factor you can get a Losi Xcelorin Sensored ESC/Motor combo from Losi Parts House using holiday discounts for $190.
Squating Goat is offline   Reply With Quote
Old 12-15-2008, 07:24 AM   #15
Trader Rating: 93 (100%+)
Default Speed
The only 2 I would consider is the speedpassion or the Tekin rs pro. Giving a slight edge to the Tekin .
latemodel13 is offline   Reply With Quote
