Old 12-12-2008, 09:53 AM   #1
Akhor's Avatar
Default Spur Gear Pitch Options
Why would you choose a 64p or 48p spur gear, assuming you had a matching pinion pitch?
What are the advantages/disadvantages of each?
Akhor is offline   Reply With Quote
Old 12-12-2008, 10:01 AM   #2
liljohn1064's Avatar
Trader Rating: 17 (100%+)
64 is quieter and you can fine tune your FDR better. 64 pitch is more prone to damage on dirty surfaces due to fine teeth.
48 is a little louder and limits the fine tuning of your FDR. 48 pitch is less prone to spur stripping and damage due to the larger tooth size.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-12-2008, 10:05 AM   #3
bs6ef's Avatar
Thats all you need to know.
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 12-12-2008, 10:46 AM   #4
Akhor's Avatar
Awesome!
Old 12-12-2008, 11:25 AM   #5
SWTour's Avatar
Liljohn nailed it ...setting GEAR MESH is my biggest reason for chosing over the other
The larger tooth 48p can be off a little on the mesh and NOT strip a gear.
The finer 64p gears, the mesh is crucial. Too tight, gear binding occurs, too loose, gears wear or strip really easy.
So depending on what type of vehicle I'm using, I'll run one or the other (I have a large stock of BOTH)
For instance in my TC3 Touring Cars, I run 48p, because adjusting the motor is sometimes difficult to move the motor just a small amount.
In my old HPI Pro2 TC, adjustment is easy, so I use nothing but 64p.
OVAL cars also easy, so nothing but 64p.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 12-12-2008, 05:42 PM   #6
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
For anyone who has problems meshing 64 pitch gears i have a super simple solution for you. you can do it blind folded. Lets say you need to run a 47 tooth pinion. Put on a 48 tooth put it tight to the spur and tighten the motor down. Remove the gear and put the 47 back on. You should have the perfect mesh. I have done this for years, i hve not stripped a gear since.
Or you can do the old toilet paper trick. Put a small piece of toilet paper between the spur and pinion and tighten it down. then roll it out and it should be close. However i find the larger pinion deal works best.
burbs is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16064 Yesterday 12:09 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Got an Xray. Now, what? (pinion/spur combination/tire suggestions) Tom G Electric On-Road 8 06-12-2004 05:04 AM
