Old 12-11-2008, 10:55 PM   #1
bkspeedo's Avatar
Default Motor or ESC Timing VS gearing for speed
Has anyone done extensive testing to find out what combination of motor timing, ESC timing, and gearing provides the best overall speed and corner exit acceleration? I realize track size, traction, motor type etc play a roll but that's why I'm posting this question. I think it would be most beneficial if the feedback was for 17.5 to 10.5 motors.
Thanks in advanced.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-12-2008, 12:45 AM   #2
decibels's Avatar
Thanks in advanced.
i run a speed passion 10.5 and gt1.1 speedy and on a fairly open track ive found that i never crank the timing more than level 6 of 8 which is 18.75 degree. On that subject though i think matching the timing with the gearing is important and then factor in the grip. i recently was running 43mm roll out on about 15 degrees of advance on the speedy and that was pretty awesome, i liked the feel. but gear the car right first and then adjust the advance for your punch. i reccomend not going below 10 degrees and not above 20. i think this because to low and the motor didnt spool and to high and it just revd all day like it never fully wound out. i was also using lipo (chargery)
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 12-12-2008, 12:46 AM   #3
decibels's Avatar
Thanks in advanced.
i forgot to add that if it is hot and motor temps are toooooo high dropping a little advance drops temps a lot!!
Team Wave Speedies
flying fox rc
Old 12-12-2008, 09:25 PM   #4
bkspeedo's Avatar
Decibels, thanks for the input. Anyone else have input on this topic?
Brent Klingforth
5280 Raceway
Old 12-12-2008, 09:34 PM   #5
C_O_jones's Avatar
http://www.rctech.net/forum/electric...nsored-55.html
C_O_jones is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
Timing vs. Power (Brushless) SWTour Electric On-Road 16 12-11-2007 05:22 AM
