Old 12-04-2003, 02:24 PM   #106
Trader Rating: 16 (100%+)
Originally posted by Raydee
Rookie, sorry but your 6 cell chassis layout with the cells on one side won't work.
Which one.....? The inline one or the stick one...? I am still waiting for mine....I bet NY is much closer then Chicago......
Old 12-04-2003, 02:29 PM   #107
Rookie here is how I mounted my six cell on the Xray. I used a thin lexan plate under the cells to hold them to the chassis.
http://users.adelphia.net/~raydee/xray15.JPG
http://users.adelphia.net/~raydee/xray16.JPG
http://users.adelphia.net/~raydee/xray17.JPG
Forget about my last post.....so, the inline layout FIT or not FIT the M18...? I knew you cannot use the stock battery holding clip/board to hold down the chassis........but you can try using strapping tape.........as long as it hold the batteries, I care the less about the look.
Also, what about the stick layout....(like 7.2V starter box stick batteries layout)............I thought that might be able to hold the battery and still able to use the stock battery holder.
Also....go try mount the BB.....they might work.
Thanks for all the report.........I am sure that will help others here.
Old 12-05-2003, 06:56 AM   #108
Send a message via AIM to Raydee
Rookie, As far as I can tell the 2/3a cells you run are going to make the difference in battery placement. I know SuperK got the stick pack to work with the stock holder but with the smaller HeCells which are only 27.5mm long. I tried it with my 29.5mm Kan cells and they would not fit even with the stock hold down removed. The inline pack did work however and is how I am going to be running my Xray for now untill the saddle pack chassis hits the stores. As far as I am concered no battery compares to the Kan cells and that is all i will run!!
I did try to fit the BB but it didn't fit the stock motor mount. I do however have a friend that used a cut down version of the MRS4 BB motor mount and then drilled holes in it and mounted it to the Xray motor mount and he is now running the BB in his Xray. He told me that the rear diff seemed to loose for the BB but the rear ball diff will fix that. I am also going to research a way to make the rear diff adjustable like the front diff today using front diff parts in the rear! It looks like it will work perfect......I hope.
Rookie by the way, great work on the rendered pics!!
Raydee is offline   Reply With Quote
Old 12-05-2003, 08:50 AM   #109
Racer4Life's Avatar
Trader Rating: 18 (100%+)
When can we expect hop-ups for the M18?
My list of items needed!!!
Front oneway
Rear ball Diff
Graphite chassis
Speed 300 motor plate
That's all I can think of for now!! Feel free to add to the list!
Tom
Racer4Life is offline   Reply With Quote
Old 12-05-2003, 09:27 AM   #110
I hope soon! I know the second shipment of Xray M18's just came to my local Hobby store and he is selling them at a great price! $97.99. If anyone is interested call them toll free 1-866-830-9922. We can ship priority mail so you get it quicker. Thanks.
Universal Entertainment Niagara Falls, NY
Old 12-05-2003, 12:40 PM   #111
I replaced the pin in the rear diff today with the shaft, two black washers, screw and spring from the front diff and now the rear diff is fully adjustable like the front! I think it will make the car handle speed much better!
Old 12-05-2003, 12:50 PM   #112
pucho's Avatar
Send a message via AIM to pucho
Hey I just got mine on tuesday. I haven't had a chance to run it yet. Im wating for the ball diffs and the graphite chassis to come out.
pucho is offline   Reply With Quote
Old 12-06-2003, 08:25 AM   #113
Don't wait run it now, it handles like a dream compared to the HPI micro!!
Old 12-08-2003, 05:11 AM   #114
jeffreylin's Avatar
R/C Tech Charter Subscriber
I just built mine over the weekend. Does the rear toe-in seem excessive? The car wanders quite a bit in low traction surface.
jeffreylin is offline   Reply With Quote
Old 12-08-2003, 05:24 AM   #115
Mine seems good! Here is a vid of my car at our local races.
http://www.wnyrcinfo.com/raydee/1207modamain.wmv
Please right click and save to your PC to view
Old 12-08-2003, 12:19 PM   #116
jeffreylin's Avatar
Can you save your movie in quicktime or mpeg format--can't see it on a mac. thanks!
Old 12-08-2003, 01:00 PM   #117
Suspended
Trader Rating: 28 (100%+)
Wow! thats pretty cool there Ray! Thats a Stock xray?Made those Hpi cars look really bad!Way more excelleration out of the corner and better corner speed!Impressive.
racenut123 is offline   Reply With Quote
Old 12-08-2003, 01:41 PM   #118
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Servos:
I'm using the 3pk with the HRS receiver currently. The HRS receiver requires a digital servo. Anyone have any thoughts on which servo might be best here.
The JR DS368 should fit perfect but it has 2 servo mounting tabs instead of the one like the HS81
The Futaba 9650 won't fit with the servo mounting blocks but it has horizontal mounting tabs that may work.
I'm debating ordering both and trying them out. I just refuse to purchase the HS81. I've had far too many problems with Hitec servos finding a center.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-08-2003, 02:43 PM   #119
MikeR's Avatar
Trader Rating: 15 (100%+)
The JR D368 is awesome... just put some spacers under the stock servo mount blocks to fit it.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-08-2003, 02:50 PM   #120
superk's Avatar
Yha...after I run it and a few hit some how it strip my servo horn. I have to get me HPI servo saver for this car. I think this is a must have for MOD motor.
superk is offline   Reply With Quote
