Old 02-24-2006, 12:47 AM   #721
Xyvern's Avatar
I'm planning to get the M18 kit but I want to use the Spectrum receiver because I want to use my M11 radio. Does this car has spece for it
Xyvern is offline   Reply With Quote
Old 02-24-2006, 02:07 AM   #722
Super Moderator
Grizzbob's Avatar
Sort of, but it depends on what servo & ESC you plan to use. I've made one fit with a proper micro servo(like the size of a Hitec HS-81, for example) & a Novak Spy for the ESC, but anything bigger & I'm not sure. In the end, you might just have to try placing it on top of the servo(which is what I'm doing now with the Motek Panther chassis I'm using, & I have to put the Spy on the upper deck, so the motor plate has room to accomodate any motor & be adjusted properly)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-24-2006, 10:06 AM   #723
duneland's Avatar
Yes, there will be space. Futaba 3101 is one of the best choices for servo. Put the rx on edge, between the servo & motor. Esc next to motor. Be carefull with balance. If you use LiPo batteries, you may have to put either the rx or esc on the battery side. Try to get everything on the lower chassis if possible.
duneland is offline   Reply With Quote
Old 02-24-2006, 04:50 PM   #724
Xyvern's Avatar
Thank you guys for the help, I think I'll get the Mamba brushless motor for my M18.
Old 02-24-2006, 05:00 PM   #725
I have the Tekin system and think it's a better setup than the Mamba, which I also have. The Tekin has onboard programming (no need for a laptop and cable) and is sealed in a nice plastic case, where the Mamba is shrink-wrapped and the ends are open to the elements. They are both great but if I could only have one..I'd get the Tekin.
RCevolution is offline   Reply With Quote
Old 02-24-2006, 08:05 PM   #726
geeunit1014's Avatar
also, i have noticed that the mamba controller sometimes "cogs" at low speeds when you hit the gas, causing a studder and then a pipe plant, where the tekin is smoother on the response
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 02-24-2006, 08:08 PM   #727
Oh yeah, and the Tekin has SOLDER POSTS
Old 09-07-2006, 08:51 PM   #728
CypressMidWest's Avatar
Default 1/18th Nationals
Could anybody let me know when and where the next 1/18th onroad event will be, particularly "the Nationals"
THNX
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-08-2006, 06:49 AM   #729
vtl1180ny's Avatar
R/C Tech Charter Subscriber
There's a forum on here for 18th scale now, check there....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 09-08-2006, 06:59 AM   #730
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
THNX
WHA?!?! Ian...what's going on buddy? Is speedmerchant making an 18th scale car now?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 09-08-2006, 04:07 PM   #731
BadSign's Avatar
Trader Rating: 15 (100%+)
THNX
Keep watching for a big announcement from Indy...
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 05-08-2010, 09:44 PM   #732
R40Victim's Avatar
I'd like to convert my slip on wheels to bolt on like the pro kit. Is it just a matter of buying these, or do I need more:
http://www.amainhobbies.com/product_...-Hex-Adapter-2
R40Victim is offline   Reply With Quote
Old 05-08-2010, 09:53 PM   #733
You just need those, and the wheel nuts (they arent included with the axles for whatever reason
Mike Gee
Old 05-08-2010, 10:33 PM   #734
R40Victim's Avatar
Thank you! Can you tell me what motor mount I need to fit a 370 motor? I see several for the pro, bu not the regular car like mine.
Old 05-08-2010, 10:52 PM   #735
This is what you want, im not sure of the part #, its cut off in the pic. I cant seem to find it on any online stores. Id you cant track down an xray one, atomic also makes a mount for the old style chassis
Mike Gee
