Old 01-29-2006, 04:25 AM   #706
crabboy's Avatar
Trader Rating: 58 (98%+)
Finally I finished my m18
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 01-29-2006, 04:41 AM   #707
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
And is it ever fast!
v0rtex is offline   Reply With Quote
Old 01-29-2006, 12:24 PM   #708
MrUnlimited's Avatar
My toy: Motek equiped with Mamba 8000KV!
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 01-29-2006, 01:10 PM   #709
MrUnlimited,
What do you think of the GPM shocks? Sweet looking car
RCevolution is offline   Reply With Quote
Old 01-29-2006, 03:43 PM   #710
Super Moderator
Grizzbob's Avatar
Hey guys, been awhile since I last posted on this thread, so I thought I should put one up of mine, also has the Motek chassis(but we just run stock 180 size motors right now, thinking about more though)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-29-2006, 11:25 PM   #711
Originally Posted by RCevolution
MrUnlimited,
The GPM shocks work great if you replace the spings with the Atomic colored springs.
Old 01-30-2006, 12:32 AM   #712
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by crabboy
Hi Guys.
Just bought a Mamba Comp. X for my m18 and it is so fast it is like no micro I have ever seen I have some GPM drive shafts in the car and the pins fell out of them. What are some of the best upgrades you can get. I allready have things like ball diffs SSG chassis and top deck but what else can I do to make it better.
Any help would be greatly apprciated
Rhys
Seems the only unis that are designed right are the Integy's since they use a grub screw to retain the pin
Quick fix for your GPM's is to get some heat shrink wide enough to fit over the joint where the pin is and shrink it down around that area- about 4mm of shrink, just enough to hold your pins in. Probably a good all around safety tip for any cvd.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-30-2006, 12:34 AM   #713
MikeR's Avatar
Awesome paint by the way fellas
Old 01-30-2006, 01:02 AM   #714
Or you can switch to a set of AVM driveshafts and wheels Like me
Old 01-30-2006, 10:53 AM   #715
TFR
TFR's Avatar
Here is mine, but I sold it.
Xray M18-cimg1088.jpg   Xray M18-cimg1091.jpg   Xray M18-cimg1092.jpg   Xray M18-cimg1098.jpg
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 01-30-2006, 12:23 PM   #716
Why? Are the GPM springs inconsistant as far as rates, poor quality, too stiff or something else? Thanks for the input by the way!
Old 01-30-2006, 02:22 PM   #717
The coil GPM used is too thin so the suspension was sloppy. I found the Atomic ones better working.
Old 01-30-2006, 02:49 PM   #718
Excellent, thank you for all the help
Old 02-01-2006, 08:47 AM   #719
Ephidelt490's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Ephidelt490
Anyone have a killer setup for the M18 on asphalt? I'm running a 2 cell 1320 LiPo and Mamba 6800 with a custom chassis. I'm just curious as to what setup would be good for Asphalt? I'm currently running:
+gaz 960RR LiPo Chassis (150mm)
+gaz Super Stiff upper deck
+gaz Heatsink Motor Mount
Team Orion Foams - F = Hard, R = Medium
Wheels are in wide position on hub (F & R)
Mazda 6 Body w/ Wing in middle position & no air dams
6 degree front caster
Atomic lowering springs - F = Light Orange, R = Blue
2.5 Degree Rear Toe
Novak XXL
Thunder Power 1320 mAh LiPo
Hitec HS-81 w/ HPI servo-saver
Mamba 6800kv Brushless
Mamba 25 ESC
Droop screws are the composite inserts in rear, about .5mm in front
The car is great, just curious as to if anyone had a better setup? Thanks!
-Adam
[Action Hobbies] [Team Associated] [Futaba] [O'Donnell Fuels] [JConcepts] [DNA Designs]
Ephidelt490 is offline   Reply With Quote
Old 02-01-2006, 09:01 AM   #720
Joep's Avatar
Originally Posted by Ephidelt490
Anyone have a killer setup for the M18 on asphalt? .... The car is great, just curious as to if anyone had a better setup? Thanks!
-Adam
Look here at one18th.com. Over 40 setups!!!
Gr.Joep
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
