Old 03-31-2004, 07:47 AM   #421
speedxl's Avatar
R/C Tech Charter Subscriber
shoot me an email as to when this is starting and i'll try and make it up there with a couple of the guys so you get some competition from down here!
we use the imrca classification for the cars.
i have the chassis pictured but he is sending me a six cell side by side chassis for the 2/3 aa batteries. that chassis is looking sweet!
for who ever is intrested for $35.00 dollars you can have one!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 04-01-2004, 12:13 PM   #422
speedxl's Avatar
Old 04-01-2004, 07:32 PM   #423
Super Steve's Avatar
Send a message via AIM to Super Steve
Super Steve is offline   Reply With Quote
Old 04-06-2004, 10:02 AM   #424
speedxl's Avatar
bet it runs nice what do you have it geared at?
Old 04-09-2004, 06:18 PM   #425
DPowell's Avatar
Powell Racing Components is proud to introduce 2 new parts for the Xray M18.
The first is the Six Shooter chassis. The Six Shooter is designed to use 6 2/3AA cells in a side by side configuration and includes a carbon fiber battery hold down brace. The 2mm S.S. chassis is 17% lighter than stock and considerably stiffer.
The second part is a carbon fiber drive shaft to replace the stock aluminum piece. The carbon fiber drive shaft is half the weight of the stock shaft. The combination of the Six Shooter chassis and CF
driveshaft will reduce the weight of your car by 8 grams. Combine that with the reduced weight of using 2/3AA cells and you've just lost 45 grams!! That is over 1 1/2 ounces. Losing 1 1/2 ounces on any RC car is significant, but on a 1/18 scale car, it is HUGE!!
Stay tuned because we're not done yet. We have more parts in the works to be revealed very soon for this incredible little car.
E-mail or PM for more information.
D.P.
www.powellracingcomponents.com
**Record setting carbon fiber**
Speedmerchant and TOP USA dealer.
DPowell is offline   Reply With Quote
Old 04-09-2004, 09:25 PM   #426
Bobby Z's Avatar
The new chassis looks great!! I really like the idea of the carbon drive shaft. Great idea!!
I have considered trying the 2/3 AA cells but I was told they wouldn't last long enough when racing certain motors. How much run time do you get with these cells and a Speed 300 (big block) type motor?
Bob
Bobby Z is offline   Reply With Quote
Old 04-09-2004, 09:59 PM   #427
DPowell's Avatar
BobbyZ,
How long are your heats? If you are running 6-8 minute heats, you should not have any problem making time. The reduced weight helps in that area also.
D.P.
Old 04-09-2004, 10:02 PM   #428
Bobby Z's Avatar
The local track was running 5 minute heats and mains. I will pick some cells up and try it with the stock chassis for starters.
Old 04-12-2004, 08:18 AM   #429
speedxl's Avatar
bobby z i drive for doug i have been experimenting with different types of cells and have come to the conclusion that the 2/3 aa kans or cbp cells are perfect even though they are only 650 mah's they make over 10 to 12 minutes of run time befor slowing down and loosing punch !
at my local track we follow the imrca rules and we run 8 minute heats and i have no problems making run time i have tried dumping and cant ( driving extremely agressive with the throttle) good luck.
Old 04-15-2004, 09:03 AM   #430
speedxl's Avatar
ttt
Old 04-15-2004, 03:26 PM   #431
Bobby Z's Avatar
Default cells
speedxl
are you running five or six cell packs with the 2/3 AA cells? also what motor are you running that allows you to make 8 minutes run time?
Bob
Old 04-15-2004, 03:30 PM   #432
speedxl's Avatar
bobby we run the imrca rules!
it allows for guys running stock motors to run six cells i run an orion micro stock!
and if you run a mod like the corless you have to run five cell i get about 12 minutes of runtime regardless of the motor, pluss we race qualifiers and mains for 8 minutes! look below here is a pick of the car!
Old 04-15-2004, 03:59 PM   #433
Bobby Z's Avatar
I will have to suggest that we start to follow those rules as well. I'm trying to decide if I want to attempt starting up a club in this area as most of the racing won't be held again until the fall.
Regardless I think that the 5 cell mod or 6 cell stock would be a good compromise. Unfortunately the club I was racing at was not following those rules and was doing 5 or 6 cell modified with Speed 300 motors.
Old 04-19-2004, 09:16 AM   #434
speedxl's Avatar
you ll find the imrca rules to be good they make it even for everyone.
Old 05-02-2004, 09:12 PM   #435
WE WILL HAVE A MICRO KING CHALLENGE ON MAY 22TH, 2004
THE RACE WILL START AT 10:00 AM.
TRACK WILL OPEN AT 8:00 FOR PRACTICE
SIGN UP WILL OPEN ON APRIL 26, 2004.
MOTOR WILL BE HAND OUT.
THERE WILL BE RUBBER CLASS AND FOAM CLASS
HPI BASE WILL RUN UP TO 6 CELLS.
XRAY BASE WILL RUN UP TO 5 CELLS.
NEW TRACK LAY OUT WILL BE DONE PRIOR TO THE RACE.
ALL RACER WILL NEED TO USE OUR TRANSPONDER.
WIRE FOR TRANSPONDER CAN BE PURCHASE AT THE TRACK.
MORE NEW WILL COME THERE WILL BE A MINI T CLASS ALSO.
MINI T CLASS WILL USE STOCK MOTOR.
UP TO 6 CELLS BATTERY PACK
THE RADIO WILL NEED TO BE ORIGINAL RADIO,
OR IF IT HAD BEEN CONVERTED IT WILL NEED TO BE ON
AM. 27 MHz ONLY. NO FUNNY FREQUENCY(45 MHz) OR 75MHz
LATER.
Thank you.
Mr. P is offline   Reply With Quote
