Old 01-23-2004, 11:37 PM   #241
Neil Rabara's Avatar
Mr. P, do you have a website for your track?
Neil Rabara is offline   Reply With Quote
Old 01-24-2004, 04:25 AM   #242
Default Official message from Xray
Xray would like to address a few issues on which we have received numerous inquiries, to make sure that we address the most frequently asked questions and issues.
M18 original kit:
It was a challenge to make a micro car that is easy for beginners to drive while still allowing professional drivers to achieve top results; we are sure you will agree that the M18 achieves both these aims. We therefore designed the M18 to be easy to drive, yet be easily upgradeable for high competition.
The M18 was designed for club racers and for new drivers, which is why it is so easy to build and have it on the track without any extensive setup. The 4° rear toe-in and 12° caster make it easy to drive and handle well, and the stock gearing gives the car a good balance of acceleration and speed for stock racing. The Power Pack includes all the necessary electronics for completing the kit and running it with a great performance. Using the stock configuration, that is stock motor, 5 cell battery pack and rubber tires, the car will handle extremely well and with high performance and without any problems at all.
Motor overheating:
To achieve the best race times in stock racing without overtaxing a stock motor and electronics, the M18 should be used with the stock 36T spur gear and 17T pinion gear, with a 5-cell (6.0V) battery pack. Note that using higher voltage battery packs, improper gearing, and higher grip foam tires may increase the stress on the electronic components (for example, a stock motor) and result in higher loads, higher heat, and decreased performance.
To run high-performance electronics such as modified motors, super size motors, more than 5 cell batteries, will require different gearing. The optional 42T spur gear and additional pinions will enable you to run these high-performance electronics without having any motor heat-related problems.
To avoid motor overheating, you should make sure that all transmission parts are clean and free from debris, so they turn absolutely freely without binding. To check this, disconnect the motor and turn the main shaft by hand to check that all four wheels turn freely and easily. Also, check for binding in any of
the suspension components, and carefully resolve the problem (for example, exchange ball-bearings, etc.).
Differential "clicking"
The gear differentials were designed and tested using the stock kit configuration, and under racing conditions the differentials work extremely well without problems.
However, the use of higher performance equipment (such as high-performance motors, higher capacity batteries 6 or more cells, or high-grip foam tires), the front diff may make a "clicking" noise. This does NOT result in any significant performance decrease. XRAY is addressing this issue. For those customers who will be running high performance electronics, high-performance options (such as alu adjustable ball differential and front one-way axle) are offered that will eliminate this issue.
Power Pack:
The Power Pack includes all electronics necessary to get the M18 ready to race. The micro stock motor gives a great performance and is a great starting point. The included XMC180 speed controller is one of the world’s smallest digital ESCs with reverse.
EXTREMELY IMPORTANT: The XMC180 ESC is designed to work only with the micro stock motor and up to 5-cell battery packs; the use of any other motor (modified or super size) will damage the ESC and void the product warranty.
The XMS01MG servo included in the Power Pack features metal gear outputs and is great for the stock M18. Using other plastic-gear servos in the M18 may result in servo breakage; as such we strongly recommend using the servo included in the Power Pack.
An optional servo saver is offered, which will help to alleviate any servo breakage issues with any type of servo.
The XMS01MG servo is not compatible with analog receivers, and the servo will not work with the KO Propo KR-301F receiver.
High performance racing:
For professional racing, high performance option parts are offered to enable you to fine-tune the M18 to achieve better results. Options include, but are not limited to, the following:
• graphite chassis with extra cooling holes
• alu motor mount
• optional gearing (42T spur and additional pinions)
• adjustable ball differential
• front one-way axle
• alu drive shafts
• adjustable toe linkages
• servo saver
XRAY has been diligently working on designing and producing additional and better parts and products for the M18 so it can be better tuned for various racing conditions.
The M18 project is receiving extra high attention for further development and continuous R&D, so prepare for plenty of cool and high competition stuff coming out!
Please subscribe news at www.teamxray.com to be informed about any new products coming out.
mario is offline   Reply With Quote
Old 01-24-2004, 08:20 AM   #243
Mario, thanks for clarifying and addressing some common problems people are having.
Old 01-24-2004, 09:28 AM   #244
mario,
Can you give us an estimated time as to when the optional high performace parts will be avaliable?
Also, are there any plans to release a "pro" version of the M18?
MADHAT is offline   Reply With Quote
Old 01-24-2004, 11:45 AM   #245
markp27's Avatar
Send a message via ICQ to markp27
Default Re: ...
Originally posted by church
here it is with the body...
Who makes the Porsche body?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 01-24-2004, 08:36 PM   #246
Big D's Avatar
What kind of Servo Saver are u guys using on the M-18.....Been Trying to find one that fits.......
Too bad the 4th of July is only once a year
http://finalthoughtsracing.wetpaint.com/
Big D is offline   Reply With Quote
Old 01-25-2004, 08:38 AM   #247
Regional Moderator
More news on the m18 at http://www.teamxray.com/teamxray/new...76f817da4dd5fc
This was just posted on XRays web site
volav is offline   Reply With Quote
Old 01-25-2004, 05:06 PM   #248
KevanB's Avatar
Heres the scanned RCCA article for all you. Let me know if its too large, I can resize it.
KevanB is offline   Reply With Quote
Old 01-26-2004, 12:12 AM   #249
Neil Rabara, we do not have a web site yet(will try to get our act together soon). However if you don't mind you can check the result and what's going at rialto track on this forum http://yourmicro.com/forums/showthre...053#post123053
We generally posted all of our result there.
Mr. P is offline   Reply With Quote
Old 01-28-2004, 05:47 PM   #250
man i cant wait to get mine they keep on selling out at socal but i need the mony first
nick b. is offline   Reply With Quote
Old 01-29-2004, 12:02 AM   #251
Thanks Mr. P. How soon did you guys sell out of your M18's?
Old 02-01-2004, 08:00 PM   #252
They stay on the shelf no longer than 4 days and then gone. As of now we are out of them.
Old 02-04-2004, 01:36 PM   #253
jc510's Avatar
Default Micro and 1/12 racing @ FastTrack
This Saturday Night 2/7/2004
1/12 stock
1/12 19 turn
Micro's
Racing starts at 7:00 pm
Call FastTrack for more info @ 916-725-1722
jc510 is offline   Reply With Quote
Old 02-05-2004, 09:21 AM   #254
rc-zombies's Avatar
jc510..
Where's Fast Track in Sacto...may have to take a drive and check it out...I'll dust off my 12 and rebuild my micro...
Old 02-05-2004, 08:16 PM   #255
jc510's Avatar
Default yes
It's in Citrus Heights, Take I-80 to Antelope right to Auburn right and it's on the Right.
