Old 02-03-2009, 02:58 PM   #121
tpczx6's Avatar
Originally Posted by KO PROPO Staff View Post
The PDF for the BMC Manager is now available here http://www.kopropo.com/america/index...d=21&Itemid=59
Thanks Robert
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 02-03-2009, 08:18 PM   #122
Trader Rating: 198 (100%+)
I have been running a BMC in stock buggy with an Orion and hacker 17.5. I have used profile 1 with great results. This speedo has so much punch. I did gear down and lowered the timing. I am going to be trying the BMC is TC tomorrow. I will let you all know how it ran.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-06-2009, 09:03 PM   #123
Well this speedo is awesome in TC 13.5. It has so much pull out of the corners. I ran a 39.09mm roll out. I still needed more gear on the motor. As it was coming of 110 after 5 minutes.
Now to get one for my 12 scale.
www.donatelife.net
Old 02-07-2009, 10:12 PM   #124
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Hey all, I just bought the BMC and have yet to run it. I am going to be testing and preparing for the TCS Trackside event. I am running an LRP 17.5 in a TA05 chassis. I am wondering what profile to run and how to gear this thing. The instructions that came with the motor say to start at a 5.0. Any help would be greatly appreciated.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 02-07-2009, 10:47 PM   #125
I would start with profile 1. That is the power profile. This is also the default. Depending on the track you may want to start around a 5.2 fdr. Check the motor temp after 3 minutes. Make sure it is not above your motor manufacture temp spec. This speedo adds allot of timing advance. So you do not need as much gear on the motor.
I was at our indoor offroad track in St Louis tonight. There was a racer with a Pulse and BMC in a B4. He said he had a bunch of initial cogging in the motor. He also had the timing on the motor advanced about 20 degrees he said. He lowered the timing and the issue went away. So just FYI like a few pages ago do not over time the motor with this esc. You most likely have issues with it. Let the esc do the timing advance. As it seems to run great with lower motor timing.
www.donatelife.net
Old 02-08-2009, 12:11 AM   #126
you have your timing set at 0,1, or 2 on the speedo?
redbones is offline   Reply With Quote
Old 02-08-2009, 07:55 AM   #127
BP SHADOW's Avatar
This is the non adjustable timing motor, so that takes one thing out of the equation. I will start at 5.20 and work from there. Thanks for the help
http://f1rclab.com
Old 02-08-2009, 10:39 AM   #128
Tried it on a duo 13.5 and 17.5, and it seems that you need to have the timing on the motor at 0 to make it work.
Old 02-10-2009, 08:12 PM   #129
Default BMC Settings & Help Page
I have been working on the BMC settings and help page. http://www.kopropo.com/america/index...113&Itemid=162
Just to get the ball rolling on it, new settings have been posted.
Also this was not written in the instructions but if you want to copy one model to another in the software, just click and drag the model number tab (you want to copy) to the desired model tab.
I will add more info later this week.
KO PROPO Staff is offline   Reply With Quote
Old 02-10-2009, 08:28 PM   #130
STLNLST's Avatar
Trader Rating: 21 (100%+)
Thanks for the info.
STLNLST is offline   Reply With Quote
Old 02-13-2009, 09:51 PM   #131
BP SHADOW's Avatar
Slightly off topic, but I have a KO Comp 2 brushed controller, and I can not get it into communication mode, keeps giving me a Communication failed error message in the software. Anyone have any ideas how to fix this. My BMC hooked up just fine, so I know its not a driver issue. Any help would be greatly appreciated
http://f1rclab.com
Old 02-16-2009, 03:57 PM   #132
The VFS-1 Comp 2 requires that you put it into program mode. The BMC doesn't require putting it into programming mode.
Old 02-16-2009, 05:33 PM   #133
Send a message via AIM to HenBeav
i finally got my usb programmer, before i had it i had the timing advance set on 2 on speedo and had to retard the motor about 10 degrees to take away the cogging, i switched the timing advance to 1 in the speedo and moved the motor timing to 0 and its much better feeling with a 17.5, also been trying the new profiles posted on KO site and really like the tc profiles haven't tried any others yet.
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 02-17-2009, 05:37 PM   #134
Scottrik's Avatar
Trader Rating: 245 (100%+)
Question re: LiPo cutoff...
Does the BMC have a choice re: number of cells for the cutoff in LiPo mode? I know the 4-cell GTB's have no cutoff option, the GTB's with LiPo cutoff only recognize 2s LiPo for cutoff. The Tekin (OH how I'm trying to not get a Tekin...if I'm going to be a test monkey I want to be paid, and let's not talk about QC...) can select 1s for cutoff.
I'm getting everything together for running 1s LiPo in one of my 1/12 cars and for safety's sake I'd like to have 1s cutoff capability.
Thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-17-2009, 06:07 PM   #135
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks,
Scottrik
the cutoffs are:
nimh 4C
nimh 6c
lipo
it can be seen here:
http://www.kopropo.com/america/downl...ualEVer152.pdf
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
