Old 12-26-2010, 03:54 PM   #1201
macdude's Avatar
Thumbs up
Originally Posted by CFR View Post
Hope there's new BMC software / hardware update rather than a new esc
+1
And the ability to update through the USB adapter.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 01-24-2011, 08:17 AM   #1202
VFS-1 BMC Modified Version #40052 and new BMC 2010 Manager software.
http://www.kopropo.com/america/index...155&Itemid=187
BMC 2010 Software VFS-1 BMC 2010 Manager (NEW)
http://www.kopropo.com/america/index...d=21&Itemid=59
The BMC 2010 Manager optimizes the voltage cut off settings for 1S Lipo and 2S LiFE. The included improvements in voltage cut off settings are three 1S Lipo (2.9V, 3.0V, 3.1V) and two 2S (5.0V, 6.0V) settings. The ESC timing now goes up to 12. Software functionality is similar to the previous versions and can also be used with ROAR Spec versions of the BMC for no timing settings. The Modified Version of the BMC should use this software to maximize it's potential.
my question,
can BMC v1.5 use the new 2010 software and set the timing to 12?
TOP Racing
krat is offline   Reply With Quote
Old 01-24-2011, 08:41 AM   #1203
Alex C's Avatar
Trader Rating: 50 (100%+)
my question,
Krat,
Thank you again for posting the info, I believe you can utilize the new software although I will check with Robert to confirm!!!
Please note if you are able to use the latest 2010 BMC Software, be very careful using the higher timing settings.
you could potentially cause the ESC and or the Motor to overheat.
Thanks Again !!!!
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 01-24-2011, 09:08 AM   #1204
macdude's Avatar
Originally Posted by Alex C View Post
Krat,
Please note if you are able to use the latest 2010 BMC Software, be very careful using the higher timining settings.
Thanks Again !!!!
I also notice that you are supplying a capacitor with the new modified version. What are the specs for this and can we use it with stock motors. I am assuming that it is similar to what Tekin is using, but just wanted to be sure before I added one to my setup.
Old 01-24-2011, 11:14 AM   #1205
BMC 2010 can be used with ROAR Spec and v1.5 ESC just as the older software could be used. The higher timing will increase heat so you will have to keep a close eye on the temps as Alex has stated.
The caps are larger then the Tekin's and are 1800uF 16V in parallel. In testing with the stock no timing class, the temps will come down and punch of the esc moves more towards mid throttle from the bottom end. These caps will be available starting tomorrow.
KO PROPO Staff is offline   Reply With Quote
Old 01-26-2011, 05:23 AM   #1206
B4james's Avatar
Under the new 2010 software with the 12 point timing, does 6 in the new settings equal the max 6 in the old software ?
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 01-26-2011, 11:26 AM   #1207
It's 6 more clicks of timing.
Old 01-26-2011, 03:04 PM   #1208
macdude's Avatar
just curious what the value in degrees is. I tried it last night. I always forget how good this is compared to every other speed control out there. It is like putting a brushed motor back in the car.
I found that with the timing on 12 I had to retard the physical motor timing in order to keep the temps down. I also dropped a bunch of teeth. All in all I could be just as fast around the track as could with a tekin. This is not in TC though this is with a Buggy inside on foams with jumps. The car is so much easier to drive its not even funny. Now if we could get just a little more rip out of it I would put it back in my TC.
Old 01-26-2011, 07:13 PM   #1209
Scottrik's Avatar
Trader Rating: 245 (100%+)
Two items:
1) Robert--the new capacitor would be perceived, then, as an advantageous addition for "spec-mode" (zero timing advance) 1/12. Running 1s LiPo if that makes any difference. If I order a couple up tomorrow via Shopatron would they ship out Priority or First Class? Traveling to a race next week and will be running my BMC(s) in 1/12 "blinky" mode for the first time.
2) DOES ANYBODY HAVE A SAMPLE PROFILE THEY FEEL IS OPTIMIZED FOR 1/12 SPEC STOCK ON 1s?
Many thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-24-2011, 03:23 AM   #1210
Halloween's Avatar
Hi, did i miss something, ore is the new software with the 12 timing not compatible for 2s lipo's?
Halewijn
l========l
['..] '' [..'] XRAY X1012 Link Wide Ed. 235mm - www.machheemstede.nl -XRAY X10 Link Rain Ed. 200mm
Halloween is offline   Reply With Quote
Old 02-24-2011, 07:08 AM   #1211
macdude's Avatar
Halewijn
NO it works with 2s lipo. I just notice it gets the motor really hot. Not as efficient as the others ESC with timing.
Old 03-25-2011, 07:39 AM   #1212
Hey guys my Ko is getting hot!
I cannot hook a motor to it without it getting really hot (to hot to touch)
The power is amazing now, but within minutes its to hot to run
I have a 13.5 geared for punch and both motor and speedo are getting to hot to quick.
Did I break my speedo?!?!?! Does the speedo know when to cut off it it gets to hot?!?!
!!!!!!!!!!!!!!!!!!!!!!!!!!!SHON HARDING!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!SWEEP TEAM DRIVER!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!VIPER R/C SOLUTIONS TEAM DRIVER!!!!!!!!!!!!
!!!!! OFFICIAL TEAM TURTLE TRAX TEAM DRIVER!!!!!!!
!!!!!!!!NEXT LEVEL ADDICTIONS CUSTOM PAINT!!!!!!!
synap2012 is online now   Reply With Quote
Old 03-25-2011, 07:58 AM   #1213
macdude's Avatar
What timing settings are you using? I would recommend getting a heat sink and a fan on the ESC. If you are going to run timing on 12 I would take and put your motor endbell to the lowest possible setting. Then gear it to what works best for your track. Temp every couple of minutes to see how hot it is getting. If you can't get the temps in a good range. Start reducing the ESC timing by 1 until your temps are good.
Old 03-25-2011, 09:12 AM   #1214
Thanks for the advice.
I think the speedo is having more issue's
I just tried to see if it was going to work, well as soon as I turned it on and pulled the trigger it got hot FAST. within 20sec it was to hot to touch!!!
DO you think its broken? It operates fine, has alot of power, but heats up instantly!!!!
Old 03-25-2011, 12:44 PM   #1215
macdude's Avatar
Yeah sounds like something is wrong. I would hook it up to the BMC software and see what you have timing set at. Then I would put it to zero and see if it still gets instantly hot. Remember too that the aluminum top is actually attached to the fets in the ESC so they do get hot while running. But it shouldn't be more than you can stand to touch.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
