Old 01-20-2009, 09:44 AM   #106
Johnny Wishbone's Avatar
What is the proper part number for the software interface for this speed control? Part number? And where is it available?
Old 01-20-2009, 11:41 AM   #107
Regional Moderator
kumpol's Avatar
Part# 61018 - ICS USB Adapter
Robert at KO Propo America told me that he is expecting to have them in sometime late this week or early next week.
Software and instructions can be found here:
http://www.kopropo.com/america/index...d=21&Itemid=59
kumpol is offline   Reply With Quote
Old 01-20-2009, 11:46 AM   #108
Thanks I have downloaded the software, BUT, has anyone had success downloading the VFS-1 BMC Manager Instructions 1.52 it gives me no option to DL or to open this article.
Old 01-20-2009, 02:49 PM   #109
m8commando's Avatar
You can also get the ICS systems instock right now at Kenon Hobby! He has plenty in stock!
www.rckenon.com
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-20-2009, 09:46 PM   #110
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Same here, the PDF is not working
Royal Rumble Racing
minicooper is offline   Reply With Quote
Old 01-27-2009, 07:18 PM   #111
RodneyB's Avatar
Originally Posted by redbones View Post
Did some research on the Japanese KO site, and there are resolutions to the cogging issues.
1. The first batch of esc comes with the setting as "model 1" where all the freq is set to the max. (default setting of the world spec kit) Try the setting to "model 3" for a smoother throttle response.
2. When it cogs, the current limiter may be kicking in. try to retard the timing on the esc(or motor).
3. When the temp goes above 70C, the thermal control kicks in. Try "model 3". Use a higher turn motor, retard timing, or smaller pinion
4. Low volt cut off may cause this too. Depending on the receiver used, you may need to change the voltage used. You may need to set the Low volt cut off setting to "Lipo" to prevent this.
I guess it has so many parameters that you can easily go beyond the accepted values for a given combination of electronics. Which in a way, is a good thing if you are a tweaker.
Interesting. I'll try changing some of these. My Orion version cogs bad with a 10.5 Trinity, and a little with a 6.5 Novak. This is in 4wd off road. Changing the profile does not affect my cogging issue. Honestly I don't notice it wrt feel on the track, but it sounds horrible and it can't be good for the motor right???
BTW, I'm running lipo battery and haven't switched it to LiPo mode yet (was running default) as I just got the cable.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 01-27-2009, 08:01 PM   #112
RodneyB's Avatar
How much does drive frequency profile affect the feel of a brushless motor? Any recommendations for off road modified buggy? 2wd and 4wd?
Old 01-27-2009, 08:17 PM   #113
I had this problem with a 17.5,13.5 and 10.5 Novak and Orion motors. After I talked to Robert(KO) I retarded the timing to the max setting and went up 5 teeth on the pinion the cogging went away. Its cause by the amount of timming that is installed in the Esc. The newer motor are also coming with a lot of timing built in so this is why we are having the cogging issue's with high turn motors.
Tonight I put it in my RB5(has a Novak 7.5 Light). Set it at profile 3 and it was awesome. It likes mods for sure. Very smooth and no cogging. I left it with the same gearing that I ran with my LRP TC.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 01-27-2009, 08:53 PM   #114
RodneyB's Avatar
Thanks. By "retarded to max setting" on timing, do you mean 0 or 2? I assumed 0, since stock was either 1 or 2.
Old 01-27-2009, 09:02 PM   #115
On the Orion I went 4 marks to the right. What ever that makes it.
Old 01-28-2009, 06:54 AM   #116
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Rodney, that probably explains why I didn't have any cogging problems with my 10.5 at CRCRC when I tried it. I had the timing retarded to the second last line....
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 01-28-2009, 12:45 PM   #117
The PDF for the BMC Manager is now available here http://www.kopropo.com/america/index...d=21&Itemid=59
KO PROPO Staff is offline   Reply With Quote
Old 01-28-2009, 02:03 PM   #118
RC MARKET's Avatar
for BMC setting card what time release ?
RC MARKET is offline   Reply With Quote
Old 02-02-2009, 11:31 PM   #119
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Are there any issues with 13.5 and 17.5s?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-03-2009, 11:07 AM   #120
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
honestly I don't know how you guys are getting cogging with your speedos. I tried my Orion 5.5, novak 10.5 and novak 13.5 with no cogging with the stock profiles. It didn't cogg at all, but it wasn't as smooth as I wanted it to be. So I went over to my buddies to use his ics and put his 2profiles on it and it's great. I tried running all those motors in my buggy, not a tc.
I tried a power cap. Little more smooth low end power. Just a lrp cap soldered to the pos/neg posts. It had more low end torque it seemed like. It was always smooth as heck, but if you tried to drive over something or what ever it needed to have more trigger. Where with the cap it was like the lrp, and had more low end power (I'm talking like 10% throttle). So I took it off, but I'm going to try it at the track for the heck of it.
But over all I really like this speedo, just needs a little tuning. If anyone has some mod wheeler profiles they made, email them to me. I'd like to try them
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
