Old 07-27-2010, 01:56 PM   #1171
radio_car_racer's Avatar
V1.5 / Profile / 10.5 / 1s
Running F109 F1 on foams and would like a guide rollout for the above
Have the software so if you have a suitable profile email me please. Address in my user profile
will be at this venue if the picture helps
http://www.ardentracing.com/shop/ski...os/openday.jpg
radio_car_racer is offline   Reply With Quote
Old 07-27-2010, 02:15 PM   #1172
buffalobill989's Avatar
Trader Rating: 50 (100%+)
dam thats an impressive track.
buffalobill989 is offline   Reply With Quote
Old 07-27-2010, 05:32 PM   #1173
Hebiki's Avatar
Trader Rating: 26 (100%+)
+1
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-02-2010, 02:19 AM   #1174
HELP
set the esc up on the home pc and all is fine
laptop & netbook in hand at the race meeting and both will load the BMC interface but won't read either esc's
have uninstalled drivers from laptop & reinstalled but still the same
both laptop & netbook both used to read the esc via the interface
Old 08-02-2010, 08:44 PM   #1175
macdude's Avatar
Originally Posted by radio_car_racer View Post
HELP
If you are using the USB dongle, then you need to add the power lead to the cord that plugs into the controller. Or you need to plug the battery into the splitter so that there is power to the ESC.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-03-2010, 06:26 AM   #1176
paraletic's Avatar
Try all the com ports in the drop down list
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-03-2010, 06:38 AM   #1177
All sorted now, all 3 pc's can read the esc. Had to reinstall drivers again on laptops
Old 08-03-2010, 06:41 AM   #1178
Li-Po Voltage Cut Offs
Does the esc auto select the voltage cut off for 1s & 2s lipo?
Old 08-03-2010, 03:18 PM   #1179
Send a message via AIM to goop
no
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 08-03-2010, 03:23 PM   #1180
stiltskin's Avatar
Trader Rating: 102 (100%+)
http://www.rctech.net/forum/r-c-item...d-control.html
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 08-04-2010, 02:18 PM   #1181
profile & role out
anyone used it with a Tekin 8.5bl motor or similar
what rollout and could you post a profile or email the kpd file please
email in user profile
Old 08-07-2010, 08:44 PM   #1182
macdude's Avatar
Default Update?
So I haven't seen any posts on here in a while about an update the timing function. I run on a small track so there is not much need for the extra straight speed. But when I go to bigger tracks I have to switch to a MMP to keep up with them. I just switched my MMP out for the BMC and I forget how much better it is than anything else in the low end. Just wanted to know where we are on a possible update. Or has that been scraped. The other question is if there will be no update, then are you planning on releasing another ESC that is more adjustable?
Thx
Old 08-24-2010, 10:38 PM   #1183
Trader Rating: 56 (100%+)
Default BMC V1 Settings
Ok, got a BMC V1 that i've been running on my WGT that has now been updated with a RS. I put this in my 17.5 rubber touring car and was wondering what factory setting to use. Thre are 5 default settings like power, smooth, touring, buggy wtc. Anyone know what would be best(if not the touring setting). Not sure what the differences are with the 5 and I dont have the USB link to find out.
dynamic_e is offline   Reply With Quote
Old 09-05-2010, 04:46 PM   #1184
How nice are these BMCs compared to the Speed Passion GT ?
I been seeing these BMC but from what i understand they still never got Software update similar to Tekin or SP ?
My main concern is how well do these compare to Tekin Speed Passion, if not using Turbo. Is it as smooth ?
-Andy
If it's Broke Fix it, If it's not MOD it !!!
CillieAcc0rd5o4 is offline   Reply With Quote
Old 09-05-2010, 05:00 PM   #1185
macdude's Avatar
-Andy
If you are not running with any timing then they are great. Very smooth power in the mid throttle. But you need to gear up with a 17.5, I would be in the 4.5 - 5.1 range for FDR. In my experience they are way smoother than the Tekin. The latest Tekin software however is very good. If you think you are going to ever want to use Timing boost I would just get the Tekin. I have 2 BMC's and I only use them indoors in the winter time. I run them in the stock buggy class. But there is really no place to use the extra power you get from the Tekin.
Anyway, for the price the Tekin is much better deal. The other controller to consider too is the Mamba Max Pro, which I also use a lot. Just getting into the new Novak kinetic for TC and so far it really rocks. It's just a little pricey compared to the Tekin or Mamba.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
