Old 03-12-2010, 03:08 AM   #1036
bluephi1914's Avatar
Trader Rating: 34 (100%+)
Originally Posted by dawgmeat View Post
Question the KO staff
At what time can we expect a profile that can run with the RS pro 203 profile, alot of races are coming up I would like to hold out on buying a ESC and hardware to keep up with guys who I was on pace with, thanks in advance.
+ 1
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 03-12-2010, 03:20 AM   #1037
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by bluephi1914 View Post
+ 1
The engineers were busy with other projects till about 2-3 weeks ago. Might start seeing new stuff in a month or two.. ???
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-12-2010, 03:26 AM   #1038
dawgmeat's Avatar
Damm 1-2 months love my BMC but I gotta come out of my pockets and my that switch
dawgmeat is offline   Reply With Quote
Old 03-13-2010, 03:36 AM   #1039
paraletic's Avatar
Default Laptop query
Hey guys just lookin into gettin a laptop so I can do trackside adjustments etc
is there any issues with windows 7 running the software
also any problems or prefernce with CPU drivers ie: AMD, intel core etc
cheers
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 03-13-2010, 03:52 AM   #1040
cheers
no issues. Im running windows 7 on my netbook and the KO software does just fine.
Old 03-14-2010, 03:19 PM   #1041
it must be 32bit version? because it won`t run on mine that is 64bit...
Steve P.
srp67 is offline   Reply With Quote
Old 03-14-2010, 06:01 PM   #1042
paraletic's Avatar
Ok well I'm no computer expert etc
but 32 or 64 bit that's too do with the CPU isn't it?
What specs will I need too run it properly without any issues?
Ie intel core or intel i5 or amd seperon etc
1.6g or 2.2g CPU speeds etc
2gig ram 4gig ram 1/2gig ram etc
cheers - jus don't wanna get one that won't work right with it
ASSociated RC12L4
Old 03-14-2010, 10:11 PM   #1043
Trader Rating: 8 (90%+)
If I were wanting to make a profile that would be suited for World GT in an Associated 10r5 what would be the best way of starting out.There are some spots on my track where I would like the advance to kick in alot sooner.Is this possible with this speedo or no. Would I just have to make large drops in the frequencies to do this. I ran profiles for twelth scale and they seemed to be pretty good. It was really comparable to the v200 with the timing at 2( KO was still faster) We were trying to spec the class a little bit but decided that most of us want to be able to run them full tilt. I ended trying a profile from a Factory driver and Man what a difference in speed!!! Though my lap times were not any faster it really seems now I have alot more to use power wise, down the back straight it was Way fast and was aksked to turn it down as some were using GTB's. So anyways really just looking for some info on making my own profiles and was kinda wanting to share what I found out last night and tonight when.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 03-14-2010, 11:57 PM   #1044
zoomster's Avatar
Default Hi M8
Hi Skinny,try the 10.5 I postered the other day,If so tell me what it was like,did not have a chance to try it .
Cya
zoomster is offline   Reply With Quote
Old 03-15-2010, 12:08 AM   #1045
is this a 1/12 setup?
Houston,Texas
Serpent 733 EVO
Old 03-15-2010, 12:20 AM   #1046
zoomster's Avatar
Hi M8 yes its for 1/12th,for 10.5 Noval Ballistic ,the other I poster was also for a 1/12th but for 4.5 the power curve is sooth down low.From what I can tell the timing you set in the speedy covers the whole range of throttle movement,not like the Tekin where you can set it up in time intervals,but from what i understand is you have to have the load off the motor before the timing really comes it if you read what Ko says it state this,I would like some comments about what I just said to see what other people think,just to be able to understand brushless motors and the way they work.
Cya
Old 03-15-2010, 02:50 AM   #1047
paraletic's Avatar
K so I've got the bmc stock manager software on a disc which I had downloaded
I can open that no problems and see the graphs etc model 1-5 etc
I connect my speedy too the USB addaptor plug it into the laptop I found the com port - com3
but when I try too read all it says read failed
I've tried without a battery on speedy with a battery speedy switched on speedy off etc
no luck
am I missing something?
This is with windows 7 premium at 32bit if that helps
ps I'm using the black and white extentsion lead between the speedy wire and USB addaptor
ASSociated RC12L4
Old 03-15-2010, 03:45 AM   #1048
radio_car_racer's Avatar
try the 3 wire red, black & white
no need to have the esc switched on or a battery connected
radio_car_racer is offline   Reply With Quote
Old 03-15-2010, 05:02 AM   #1049
paraletic's Avatar
I tried without any leads just straight into addaptor
it lights up the led but still won't read regardless switch on or off just says read failed?????
Do I need too press and hold the mode button or something?
ASSociated RC12L4
Old 03-15-2010, 06:29 AM   #1050
no
have you installed the drivers for the usb adaptor?
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
