Old 01-12-2009, 03:10 AM   #91
Originally Posted by theisgroup View Post
you may have to get the settings adapter and set the speedo. i believe that the default config is 5-6 cell. in wgt you are running 4 cell. that may solve your coging issues
I have the usb setting adaptor and have changed the unit to run 4 cell I changed the standard settings and timing etc but the unit still cogs badly. I have also now tried a 6 cell pack and a different motor (Nosram 10.5 evo) and its still the same. An email is off on its way to ko and orion!
Smartypants is offline   Reply With Quote
Old 01-14-2009, 12:17 PM   #92
jonest's Avatar
Does the speedo support sensorless and brushed motor?
Thanks.
jonest is offline   Reply With Quote
Old 01-15-2009, 09:40 AM   #93
Thanks.
No and No
Old 01-15-2009, 11:13 AM   #94
Send a message via AIM to HenBeav
Thanks.
just sensored brushless
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 01-15-2009, 01:51 PM   #95
jonest's Avatar
Thanks Henbeav & Smartypants,
Seems like I've to keep the LRP TC Spec just in case I've to run brushed... hmmmm but reviews of the speedo is good...
Thanks.
Old 01-19-2009, 10:06 AM   #96
so how bad is this cogging issue? Been a KO fan from the brushed days, but I don't want to spend lots of money on a speedo that is less reliable than my Sphere. Any word from the manufacturer?
redbones is offline   Reply With Quote
Old 01-19-2009, 10:18 AM   #97
Boosta's Avatar
Default cogging??
bit of a newb question but can someone explain what cogging is please?
Boosta is offline   Reply With Quote
Old 01-19-2009, 10:11 PM   #98
Did some research on the Japanese KO site, and there are resolutions to the cogging issues.
1. The first batch of esc comes with the setting as "model 1" where all the freq is set to the max. (default setting of the world spec kit) Try the setting to "model 3" for a smoother throttle response.
2. When it cogs, the current limiter may be kicking in. try to retard the timing on the esc(or motor).
3. When the temp goes above 70C, the thermal control kicks in. Try "model 3". Use a higher turn motor, retard timing, or smaller pinion
4. Low volt cut off may cause this too. Depending on the receiver used, you may need to change the voltage used. You may need to set the Low volt cut off setting to "Lipo" to prevent this.
I guess it has so many parameters that you can easily go beyond the accepted values for a given combination of electronics. Which in a way, is a good thing if you are a tweaker.
Old 01-19-2009, 10:49 PM   #99
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Will the ICS program work with Vista?
minicooper is offline   Reply With Quote
Old 01-19-2009, 11:03 PM   #100
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
yes.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 01-19-2009, 11:09 PM   #101
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by DirtyDog3375 View Post
yes.
No it doesnt? On the programmer package it says not vista compatible, did they change that? My buddy has one and was bummed because he doesnt have a laptop with XP
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-19-2009, 11:17 PM   #102
vista pic attached.
I have been using it since I got the esc. It works fine for both the KO and Orion esc. I have used both. Both brand esc have exactly the same profiles and settings. (just different stickers).
Hope this helps.
Old 01-19-2009, 11:32 PM   #103
minicooper's Avatar
yes.
Thanks DirtyDog. I was worried about that
Royal Rumble Racing
Old 01-19-2009, 11:51 PM   #104
vista pic attached.
Hope this helps.
Huh, thats awesome!
Now any info on the set up? Were used to the castle kind of setup, graphs, and all that. Not the numbers. Is there a guide or something?
Thanks!!
Old 01-20-2009, 01:00 AM   #105
Originally Posted by BlackedOutREVO View Post
Huh, thats awesome!
Thanks!!
I am assuming you are referring to the drive freq?
Values from 1 to 52 (over 32 steps)
1 being the lowest (smooth)
52 being the highest (power)
There are some Japanese profiles around (but I didn't like them as they use heaps of drag brakes for both offroad and touring cars)
Hope this helps.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
