Old 01-30-2010, 11:02 AM   #976
Originally Posted by amuse View Post
So I go to the link and plug in my numbers and it comes back 78 spur 43 pinion. This is gearing for a high speed oval car. Anyway is this correct? Do other people with a 17.5 brushless run this type of gearing? The FDR is 4.1
Freezer7676 is offline   Reply With Quote
Old 01-30-2010, 07:45 PM   #977
Johnny Wishbone's Avatar
Depending on the track size, we have run as low as 3.8 with 17.5 and this sc so 4.1 is a possibility.
Old 01-30-2010, 08:15 PM   #978
Trader Rating: 8 (90%+)
When using the pc program and am finished writing to the esc. I want to pick which model I want to use do I just click save or.....
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 01-30-2010, 08:28 PM   #979
When you load it you should get 5 profiles the one your after is on profile 5, to make the sc run that profile hit the "write" button, that will ensure your on profile 5, you can go back after and double check which profile your on with the led flash indicator on the on/off switch.
Old 01-31-2010, 04:27 AM   #980
zoomster's Avatar
Default Ko BMC + Novak Booster
Hi can anyone answer this question.I am running a 1/12th 1 lipo pack,with the Ko BMC speed controller,with this speedy you use the switch to do setups,but with the Novak smart Boost it states that you leave the speedy switched off and only use the Novak Boost switch to turn the car on.What I want to know would turning this on to program the speedy blow anything up as you are using the Booster to power the radio,speedy.
zoomster is offline   Reply With Quote
Old 01-31-2010, 11:24 AM   #981
Trader Rating: 198 (100%+)
Arrow
If anyone is looking for an ICS usb adapter I have one for sale here
http://www.rctech.net/forum/r-c-item...b-adapter.html
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-01-2010, 05:30 PM   #982
So was there any software that was tested at the Snowbirds?
Houston,Texas
Serpent 733 EVO
Old 02-01-2010, 05:43 PM   #983
No nothing new was ready for this event.
KO PROPO Staff is offline   Reply With Quote
Old 02-01-2010, 05:51 PM   #984
K, Thanks, your following statement sounds promising!! I cant wait t see what you guys are working on.
Houston,Texas
Serpent 733 EVO
Old 02-01-2010, 09:17 PM   #985
Alex C's Avatar
Trader Rating: 50 (100%+)
I also run the Novak Booster with my Ko BMC Speedo, however if I understand you correctly it appears you would like to program your speedo with the BMC Manager Application.
If so I would recommend to use only the USB adapter to provide power to your ESC and insure that the battery is not pluged in upon this step, or else you risk damaging either your ESC or USB port on your computer.
Although if you plan to change your profile on the ESC, you should not have any issues by leaving the ESC Switch on during this process.
For example I currently change my profiles by selecting the PB located on the ESC switch and turning the booster on during the selection process of the profiles loaded on the ESC.
Hopefully the above mentioned steps help, if you have any other questions or if there is any need for further clarification.......... please feel free to respond back!!!
Best Regards!!!
Alex
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 02-02-2010, 02:42 AM   #986
zoomster's Avatar
Hi Alex thanks for the heads up,also was able to get in contact with the novak people,and he also suggested to take out the red plug wire to the speedy,so no voltage is going to the reciever from the speed controller therefore only leaving the voltage from the novak boost,thanks and will try what you have stated.
Cya
Old 02-02-2010, 05:27 AM   #987
zoomster's Avatar
Thumbs up
Hi Alex C got a update ,just got it working ok here is my steps.
1-Removed the +(Red) from the Speedy and leave out ,cut off
2-Plug the USB and lead (White,Black) into the Speedy reciever lead,so nows it is Black,White to Black,White
3-Plug the mains battery power in this case 1C pack
4-Switch the Speedy switch on,p.s no need to switch the Novak Boost on,this now powers the USB as the USB has no power coming from it to the Speedy
5-Now start up the program,select what com post the USB drivers are using,in my case it was COM port 3.
Now I can have fun.
Cya
Old 02-02-2010, 10:17 AM   #988
What motors are you guys using at the moment. I am using a 17.5 Novak and am just wondering who has done any testing with say a SP v3 17.5
Houston,Texas
Serpent 733 EVO
Old 02-02-2010, 10:24 AM   #989
Alex C's Avatar
Skinny,
I'm currently testing with a 13.5 / 10.5 Duo2 Trinity, and had a chance to test a 10.5 LRP X12.
For the most part testing has been very fruitful, although nothing to divulge as of yet!!!
I'll keep you posted as to any new developments..................Best Regards!!!
Alex
Alex Cortez
Old 02-02-2010, 10:37 AM   #990
Thanks Alex,
I am going to test melvin's profile this evening with a novak 17.5 and maybe a SP v2 17.5. My track is 75x40 medium grip carpet.
Houston,Texas
Serpent 733 EVO
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
best esc for touring car devin4444 Electric On-Road 48 05-02-2016 10:01 AM
Foam tire spec chassi!! Team_Elli Electric On-Road 15 07-28-2009 07:26 AM
KO BMC vs SP GT2.0 vs LRP SXX krat Electric On-Road 36 07-11-2009 07:18 PM
Orion Vortex BL Race ESC dr_hfuhuhurr Radio and Electronics 29 03-02-2009 07:46 AM
